Question about Honeywell Heating & Cooling
Honeywell T8090A1007 Chronotherm Thermostat how do you set the clock?
  • 49 Answers
SOURCE: Thermostat malfunction
You may want to shut the breaker off to your furnace or air handler, or if you have a packaged system turn it's breaker off. This will kill the low voltage to the stat possibly allowing it to reset. I would also try to reset it after you turn your breakers back on.
Posted on Dec 23, 2007
rickzilla
  • 706 Answers
SOURCE: my husband &i just purchased
Hello.
here is a link to a website that will provide you operating instructions. Hope this helps...
http://www.hannabery.com/t8611tstat.shtml
Regards
Posted on Sep 23, 2008
SOURCE: My chronotherm thermostat pannel wont
Push on the little reset button on the back (print) side
Posted on Nov 04, 2008
  • 252 Answers
SOURCE: need help programing a honeywell thermostat T8095A1002
Go Here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Posted on Apr 10, 2009
  • 252 Answers
SOURCE: I have an old Honeywell thermostat (Chronotherm
you are not geting AC power from the furnace
Posted on Sep 27, 2009
Manual foe a RCH9300WF
It's pretty basic actually. I've done this with Nest and Honeywell Lyric. The only thing you need to do is removing the current thermostat from the wall and connect the new one.
Set it up using your mobile application and you're good to go.
Dec 23, 2015 | Honeywell Programmable Thermostat Heater
Replacing chronotherm with new rth7600
R= power in G= fan Y= cooling W=heat O= heatpump reversing valve C= common used for clock on chronotherm Usually its pretty streight forward wire for wire. Unless you have a heatpump. The thermostat has to be heatpump compatable. And I ll usually use the 8000 for this. The w and y jumper may not be necesary on the new thermostat as the new one should do it internally once programed as a heatpump thremostat. At least thats how the 5000 and 8000 sreies work. So imagine the 7000 would be the same. You may also have to program the reversing valve operation not all manufactuers do it the same . Some valves have to be powered for heat while others have to be powered for cooling. Good luck
Jun 16, 2013 | Honeywell Programmable Thermostat Heater
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
My honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Jan 22, 2010 | Heating & Cooling
Old analog chronotherm - clock broken
Unfortunately, no. These clocks fail frequently.
Jan 12, 2010 | Honeywell Heating & Cooling
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T882 Chronotherm Clock Thermostat needs replacement
The two wires from the transformer are to run the clock in the old thermostat. If you connect the two other wires to any heating thermostat, it will work. Don't forget to disconnect the transformer wires. Hope this helps
Nov 10, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
674 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
