Question about Garden
I bought a montgomery ward riding mower 1980's. it worked fine while testing. So i purchased it, i got half my own lawn mowed then started to smell a burning rubber smell, stopped and looked around. didnt see anything, so got on it again. Then it stopped moving, still running but not moving. If you put it into a higher gear it wants to move, you can hear it shift and rpm moter high but wont go. im guessing by the looks of it that it looks like the belt was grinding or burning and it looks like the pully in back stopped moving. Cant move by hand . Could it be the pully system or what else could it be? Sounds like trany is working but not able to move and you could see were belt was ginding on body creating the burning smell. Fluids fine,mower realy old, but ran good before. If it is the pully were can i find another i cant find mongomery part anywere. Universal mabye? Please help i spent to much on this and cant loose the money to get another. previus owner stated he replaced clutch but did all other maitnance regularly. Could the clutch be the isse or clutch pully.
  • mikeandjen4e Oct 10, 2010
    once this is complete and if it still doesnt run what else could it be
    if its not the pully what else could it be
  • 2,019 Answers
Pulley bearings sieze up all the time. They are universal and easy to change, but you could probably take the old one apart and just clean and grease it as well. Just make some wood ramps so you can get under neath to work on it. Might be best to change the belt by this point.
Clutch is not likely an issue since it was working at the beginning you were not really using it much while you were mowing.
Posted on Oct 10, 2010
  • Kirk Augustin
    Kirk Augustin Oct 10, 2010
    The pulley could be spining freely and still be the problem if the belt is slipping. There is usually a spring that pushes the tensioning pulley, to keep it tight.
    But another problem could be the brake being stuck on.
    The clutch could also be slipping because the linkage could be binding in the down position.
    Or the transmission could have one of those infinite ratio friction drives, where a rubber ball is squeezed between 2 plates at 45 degrees.
    The thing is to see if the input shaft to the transmission is being turned.
    That can be a little dangerous, so make sure the back wheels are off the ground, and nothing can touch the belt.
How to get my montgomery ward lawn tractor to start
What have you done sop fat on this? What does it do exactly?
Sep 30, 2016 | Montgomery Ward Sewing Machines
Idle pulley off a Montgomery ward 16-42 7 speed will work on a club cadet mower
You need to spec it out to know if will. Diameter, Height, offset, and if it V groove or Flat. In most cases they don't swap out that easily as Cub Cadet (MTD) products are usually very picky about these things just like their belt sizes.
Jan 29, 2015 | Garden
I can't get the deck to ride/cut evenley on my montgomery wards yard tractor
check your blades,Needs to be leveled , Possible bent deck.
Jun 19, 2014 | Briggs & Stratton Garden
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Apr 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Hi i have a montgomery wards riding mower 1990
I might know what the problem is, on those models there should be a ignition switch, or a killswitch under the seat of the mower. When the 2 people sat on it, it might have jarred or broke the switch. You might want to check it to see if thats your problem. I hope this might help.
Nov 02, 2009 | Garden
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Sputtering Mower
It might not be disengaging the mower deck all the way off. I had this problem on an older model.
May 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
