Question about Dryers
I have 2 loose blue wires that come out of the factory wire loom in my Maytag Neptune MDE5500AYW that came off the wiring block when my kids were switching from a 3 wire to a 4 wire cord. Now I am not sure which blue wire goes on which stud and whether they go on the red, black or green post.
  • hotairgerg Oct 10, 2010
    Thank you very much. I had one stud with 2 black wires coming to it and the other end had a stud with nothing coming to it so I took a chance and put the blue wires on the empty stud and it seems to be working. i appreciate the diagram as well.
  • Dryers Master
  • 8,220 Answers
You got L1 N and L2 the 2 blue wires connect on L2, check out this schematic for your dryer
Posted on Oct 10, 2010
  • Dan Webster
    Dan Webster Oct 10, 2010
    one of them blue wires connects to the motor cent switch which powers the element. The other one works the interior light.
  • Dan Webster
    Thank you
Maytag dyer problems
it sounds like the control board is going bad but i wouldn't buy any parts for this dryer,soon you won't be able to get parts for it,put the money into a new dryer not to mention that the neptune products is what took maytag out and now whirlpool owns maytag.you could also have a problem with one of the connections or a bad wire in one of the connections and when you move the wires it's working again and this could be from the heat,after years the wires get brittle,you could buy the new board,put it in and if it's a wire you're back to square one,but from what you say it's either a wire in one of the connections or the board.good luck with your dryer.
Nov 12, 2013 | Maytag MDE5500AYW Electric Dryer
Maytag Neptune door won't lock, or start the was cycle.
check all wiring for tightness and any corrosion from door latch up to the central control unit first,if ok then replace door latch component as this part wears out quickly you will need to remove washer top,then door boot spring to release door boot from door frame to access wiring to door lock component
May 06, 2012 | Maytag MDE5500AYW Electric Dryer
We have a Maytag Neptune mde5500ayw electric dryer, with a three prong cord. Our new house has a four pronged outlet. I purchased the correct 4-prong cord, but need to know the proper way to wire it into...
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
GENE
Oct 12, 2011 | Maytag MDE5500AYW Electric Dryer
I have a maytag neptune dryer #MDE5500AYW and I am trying to convert from a three prong to a four prong connection. the four prong has a red, white, black and green connection. the old three prong, had a...
yes,hook up the black with the black the white with the white and the red where the blue was,now the green is just a ground wire,all you have to do is connect it anywhere to the metal frame of the machine just to ground it,look around there should be a screw somewhere near the other wire connections if not remove any screw and connect it and it will be fine.
Sep 04, 2011 | Dryers
Its a burnt wire past the plug in outside the dryer area ,but you can see it without taking things apart just inside the machine do i just order the wire or what caused it i bought the dryer a couple...
if the wire is burned at the plug then cut it and redo,loose connections cause wiring to burn so make sure connections are as tight as can be to avoid this.........
Feb 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We have a dryer model mde5500ayw with 3 wire cord the question is if this dryer can work on 120 V.
there should be a sticker right on the back that provides that information but generally dryers only run on 220 v
Nov 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Something is stuck in dryer, possible kids toy
that means it just has too much clothing in it, take some out!
Mar 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Just need to know where the blue wire goes on the termianl block on my maytag atlantis
blue should go on l2
but for a clearer definition i am including a link to the actual schematic
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47834&diagram_id=677023#d677023
l2 should be the red leg of your chord connection
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Black and blue wires from terminal block have burned.
hi thanks for the question cut the wires back to get to good wire and re attach to block the appliance doc
Sep 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
