Question about Bushnell ImageView 11-8321 Binocular
When i press snap in normal mode nothing happens and i took a 22 sec video and it flashes a green screen is it pretty safe to say the camera is broken
Stuck in video mode
I had the same. I plug it into the computer and unplugged it several times, took out the micro SD card. Finally it said "no SD" after a while. Pulled out battery and put back in then plugged into computer again, and back to normal it seems. Sorry this is not a step by step but I was just trying random things till it worked. Did not re-test to see if it is OK for the next recording session.
Feb 21, 2012 | GoPro HD Hero 960 Video Camera
When I put my printer on, both the red 'on' light and the 'green' problem light are flashing intermittetly . I have tried to reset the printer by pressing the 'green light' down for a few seconds..but...
when I put my printer on, both the red \'on\' light and the \'green\' problem light are flashing intermittetly . I have tried to reset the printer by pressing the \'green light\' down for a few seconds..but nothing now happens on this mode. I have also turned the printer off and back on again, and lastly took the power cable off and back on again..and still no joy..any ideas
Nov 02, 2010 | Epson Stylus C46 InkJet Printer
Problem with ASUS P5GD1 mobo
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
Feb 05, 2010 | ASUS P5GD1-VM Motherboard
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for...
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Jan 19, 2010 | Dell Latitude D610 Notebook
Sony DSC H-5 Camera slow response time
you might have switched the shooting process to timer mode. please refer the instruction manual to change it back to normal mode.normally there will be button near the lcd screen with the symbol of a timer deviice. if you click it once it sets the delay of shot to 2 sec and for the second time to 10 secs.and for the third time, it goes back to normal mode. thanks for using fixya. please dont forget to rate my solution!!!
May 29, 2009 | Cameras
Safe guard mode
Turn off the camera and put it in a cool, dry place for about 30 minutes, then turn it on again.
Sep 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
My camera gets stuck on the pb mode it does not turn off or switch to camera mod
Had the same problem twice. once solved it by taking out the battery.
This didnt work the next time it happened. but i could access the camera mode. reorded a short movie clip and problem was gone.
Jun 26, 2008 | Canon PowerShot G3 Digital Camera
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Bushnell ImageView 11-8321 Binocular Logo
35 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
