Question about Vacuums
I have only had my chainsaw for 1 month and all of a sudden it will not start. what do I look for.
  • 1,040 Answers
Pull the spark plug out and while it is still connected, put the plug against the head of the motor and pull the starter. You should be out of bright light while you do this so you can see if it gets spark. And if you are holding on to the plug wire when you pull, you may get a little shock; BUT THAT'S GOOD! That means that the coil is good. If you don't get spark, then the coil is bad. Remember: You must have the ON/OFF Switch ON, (if it has one), when you do this.
If you need more help, let me know.
Jim
Posted on Oct 10, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
Gas to oil ratio for dayton chainsaw model 2z971
Hi montorsewill...
You will use a 50:1 Oil to gas ration...1 pint of 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Sep 02, 2011 | Vacuums
Hi Our H20 Mop is just over 12 months old and when we start it up the red LED light will not change to green nad will not steam up. When you run your hand down the machine you can feel a little bit of...
Hello
Our (POS !!!!) H20 Mop is just over 20 months old,suddenly became inoperative....
At startup,LED lites red,shortly thereafter changes to green,however NO steam out unit & an audable 'humming'
type noise comes from the unit.
Whatcha got ????
Alf
Oct 29, 2010 | Vacuums
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
The small belt attached to the roll brush keeps slipping off. It's a brand new belt and the vacuum is only 1 yr old.
The small belt rarely gives the problem you describe. The larger belt can jump off if the belt is worn or if th roller gets caught on something suddenly.The belt should be replaced every 9 - 12 months. If your carpet setting is too low this will cause the belts to wear faster that the estimated given time
Oct 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacement battery for a Shark rechargeable sweeper
Sure, take a look on amazon for replacement.. here: Finally charging for our multi device world. I hope this was helpful. Cheers
Feb 17, 2009 | Vacuums
Mc Culloch chain saw
You will need a parts breakdown and exploded views to start with as well as a manual , All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
After that is done then you can see the fuel filter and line inside the tank you will need to replace, take your printed views and manual to the nearby lawn mower shop and they will help you get the parts you need even if the original ones are not available. blow out the carb with chemtool and install the parts, use NEW GAS, NEW OIL and from that day forward never leave fuel in a unit for more than 3 months. Good Luck...
Aug 18, 2008 | McCulloch MC1275 Steam Vacuum
Bissel proheat is not sucking up water
There is a oblong black seal that sits where the tank lip and the clear noozle window come together, is it there. Also make sure the filter in the tank lid is clean.
Jul 09, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
140 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
