Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Hampton Bay Classic Collection 52" remote ceiling light/fan
Have separate wall switch for fan & light with remote also, sometimes switches don't work -- remote doesn't work at all now. Need detail wiring diagram to double check installation - if it worked after installation, what would cause it to malfunction now? Thanks for any help, Norm
  • dedwardmathe Dec 05, 2008
    we bought the argenta model of a hampton bay ceiling fan, last one, no instructions with it! can't seem to find anyone with help to wire it in. web site says the model number doesn't exist, 61413? any help out there?
    Dale
  • Amy M Jan 13, 2009
    Just installed like 3 months ago. Worked great, not remote dead - even after I put new battery - red light blinks on but fan & light do nothing. This was my fear of a remote fan & light in my bedroom and sure enough I can't operate except on the switch. Then only light/fan combo is option which doesn't help for sleeping! Anybody no what the heck is wrong with it? Worked perfectly fine prior to now.
    Amy
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
The wall switch has to be on for the remote to work. You should only be using the remote.
Posted on Jun 20, 2016
    Problem Solver:
Rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
Posted on Jun 04, 2008
  • Race Chair
    Race Chair Jun 16, 2016
    Lights are a simple on off and sometimes coupled with a dimming capability. Fan is either selecting different pin out on motor or with the use of Capicators in series with the power. Smaller the capictor the slower the fan/larger the faster. Mostly between 3 and 8 mfd.
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
Neither remote or wall switches will operate Hampton Bay 52
Check your wall switch you either lost your neautral or have a bad connection on your switch. Solution check white wires that are twisted tougher in wire nut and check the black wires on switch to make sure one of them don't pull out . Over time the black wires pushed in back of switch can work loose .
Jan 24, 2012 | Hampton Bay 52 In. Ant. Brass Redington...
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Remote will control fan but not lights
Hello :
It seems that the lights wires are not wired correctly . Check them at the wall switch .
good luck .
please rate !
Apr 03, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Ceiling fan is controlled by dimmer
Yes, if the hot wire going up to the fan is coming off the dimmer, it is reduced voltage and will slow down. There maybe a separate hot from another switch??
Jul 26, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Apr 26, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 52" Classic Collection Almeida 52101916
Electricians can be so much fun can't they ? LOL I would ask the electrician to bypass the remote to check the fan operation first. You need to know if your problem is the remote or the fan itself.. A simple wiring change in the junction box can be done to determine which issue to focus on.. Hope this helps..
Aug 04, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
1,501 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
