Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Unable to go wireless...message says cable is not connected to the network adapter "Local Area Connection"
    Scholar:
  • 39 Answers
Local Area Connection is the description of your RJ45 network port on your computer. In other words the jack where you connect a physical cable to (looks like a bid telephone jack) If you don't have a cable plugged into this port then the computer will display that message.
However you say you can't connect wireless so the issue is elsewhere and there are several steps you need to follow in order to do this. Keep in mind I will give you basic steps which you may know already but because your question is lacking some details I will try to cover as much as I can but before I start check your computer for a wireless adapter switch, sometimes this will be turned to the off position and your wireless card shuts off. So if its not that these are the steps.
1. The first thing you need to do is make sure your internet connection is working because even if you connect to your wireless router, if its WAN connection is not on you'll never surf the web. 2. The best way to test this is to connect directly to your Modem with a network cable so just disconnect the cable from the router's WAN port and connect it to your computer. 3. If you can surf the web you have WAN connectivity. 4. Now connect the cable back to the router's WAN port and get another cable so that you can connect from your computer to the back of the router on one of its ports labeled 1,2,3, or 4 I usually just use port 1 5. Check and see if you can surf if not, depending on your type of Internet Service Provider(ISP) the steps will be different depending if you have DSL or Cable. 6. Either way you'll need to go into your router's configuration screen and set them there. This router has 3 revisions so the steps may be different I'll give you the latest revision's steps. 7. Open a browser window and in the address line type http://192.168.0.1 then hit enter 8. You should get a pop up window asking for username and password Dlink's default is admin for the username and leave the password blank. 9. It should take you the setup page and what you're looking for is the Status page so look for status on the top right and click on it. 10. In the status page look for a valid ip address and default gateway from your ISP it cannot be a 192 number and it cannot be a 169 number usually its a 2 digit number like 61. or 73. 11. If you don't get a valid ip address then you'll need to contact your ISP for specific instructions on connecting a router to your modem (ex..some Cable providers use MAC address authentication while some DSL providers use PPPoE authentication) 12. Once you get a valid IP address the next thing is to check that your wireless network on the router is not disabled. In your router configuration click on Setup on top then Wireless Settings on the left. 13. Make sure there's a check on the Enable Wireless box. 14. You can name your router by typing a name in the wireless network name box (this is the SSID) 15. If you want to set up the security on it then scroll down to set up your wireless security type and your wireless ssid password. Save all your changes by clicking the save settings button. 16. now search for a wireless network to connect to and look for the name you gave your wireless network and connect to it using the password you set.
Good luck
Posted on Oct 10, 2010
    Scholar:
  • 42 Answers
Yes, and of course the whole point of wireless is that there is no cable connected!
Did you get a disc with your router? If so, run the disk with your adapter connected.
Ah... you do have an adapter connected, don't you? If not, you will need to buy a wireless adapter to plug into a USB slot on your PC. A wireless router works by receiving a signal from a wireless transmitter in the PC, or from an adapter attached to the PC's USB slot. If you don't have an adapter, you can get one for about £20 to £30. It's definitely worth the money, I assure you!
If you do have an adapter but the router can't 'see' it, you need to check a few things. Check the adapter is properly connected. Check its properties by clicking on its icon in the taskbar - make sure the signal strength is sufficiently high, and that the adapter is attempting to connect to your own router, and not the equipment of someone across the road.
If the router came with an instruction booklet, it should explain how to connect using the wireless facility, and these instructions are usually helpful and well-written. Most importantly, the booklet should tell you where to find the crucial information to type in the first time the adapter tries to 'find' the router. In fact, many routers have a sticker with the wireless connection code stuck to the router itself somewhere, so if you can't find the booklet, look for a sticker on the router itself.
I hope that helps a bit. Good luck!
How do I configure windows 7 for connection?
What type of connection?
Are you trying to connect to the wireless network or you are connecting your computer with the Ethernet cable.
Open Network and sharing center.
Go to Change Adapter settings.
You wil find Local area connection. Make sure that it is enabled. Local area connection is for wired connection.
If your computer has wireless adapter then you will also find wireless network connection. Make sure that it is enabled.
Right click on wireless network connection and go to Connect/disconnect.
You will available wireless networks. Select the network that you want to connect.
See Linksys router how to
Jan 06, 2012 | Computers & Internet
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
My linksys wpc54g repeatedly says "network cable unplugged" then reconnects
WPC54g is a wireless adapter. The message that you are getting is the message for the Local area connection. This message has nothing to do with the WPC54G. This message is for the wired connection and not for the wireless connection.
May 16, 2010 | Linksys WPC54G Wireless-G Notebook Adapter...
Keep stating network cable upplugged
The message is from you wired network adapter not your wireless adapter.
Go to Network Connections and open the Properties of your wired Local Area Connection (LAN) adapter. Change the notification setting at the bottom of the window.
I hope this helps.
Apr 16, 2010 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
Network Connections missing icon. Plus others problems.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
Jul 31, 2009 | Computers & Internet
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
94 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
