Question about Procom (CGL100MZ) Infra-Red Heater
I have a Model#CGL 100MZ, 10,000 BTU/htr, fuel type LP. I am looking for an Owners Manual.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
What does it mean when the power light (the small round light on the front of the heater that indicates the heater is on) is red instead of green?
was reading a rinnai pdf today about this, green means that the unit has power the red means the burner is operating so it just tells you when the gas is going basically, may not be the same for this rinnai model but is on the energy saver 556 so hopefully that explains your heater for you it should be in the owners manual if you have one as pdf i was reading was manual for another rinnai if you don't have a manual you can try downloading just type heater name and model into your google search with manual mentioned there too should bring up a pdf or a link to manual
Nov 16, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Looking for parts list for a reddy heater demon
Try www.desaparts.com
You will need the actual model number for the heater.
Nov 05, 2010 | Reddy Heater-10,000-30,000 BTU L.P.
I have welder Hobart Champion 10,000. I need an electronic board. The welder doesn't send electricity
It looks like Hobart made 3 different versions of the 10,000. If you go to their website and enter the model # (and serial #), you can download the exact owners manual with complete parts listing (according to their site). The website is: http://www.hobartwelders.com/service/owners-manuals
The part should be available from them..or with the part number, you can google it and see what is out there in the secondary market.
Hope this helps
Jul 24, 2010 | Hobart Welders 500433 Champion? 10,000...
I got a yellow flame on my Sunjoy Idustries patio heater model G-P018PSS and the flame is to big.
some of these items are engineered for a certain type of fuel. Some take propane some natural gas and other LP. take a look at your owners manual, it will explain what type of fuel to use and if you can convert your heater to the fuel that you are using.
Dec 05, 2009 | Sun Sport & Outdoor - Others
Need owners manual is there a fuel filter on this type model?
yes there is a fuel filter.remove the four screw that hold on the side cover.the fuel line is right there.remove the fuel line and pull the rubber grommet out of the fuel tank.should be a plastic tube.inside the tub is the filter.you can remove it carefully and blow it out,once you clean it out reinstall it.......to get an owners manual go to http://www.portableheaterparts.com/
Mar 03, 2009 | Reddy Heater-30-55,000 BTU Variable
Pilot does not lite
I took mine to a local repairman. He fixed it.
Sep 25, 2008 | Procom (CGL100MZ) Infra-Red Heater
Procom (CGL100MZ) Infra-Red Heater Logo
51 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
