Question about Nintendo Wii Console
My wii console is not turning on, can you help me?
  • 166 Answers
F ur console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
still the same problem,don worry check out the following Repair Guide.....
CLICK HERE
Posted on Oct 10, 2010
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
My wii works but my controler dosent show up on the screen but the buttons work i need help
Usaully,
I don't know about the Wii but I know what happens with the light on the Wii
Green - The Wii Console is on
Yellow - You are connected to Wiiconnect24. It's harsh not to keep the "Yellow" light on because it could overheat the Wii Console. So if it's "Yellow", put your finger on the "Power" Button and keep it there for a long time. When you push it, it will start with Yellow then turn to Green then keep the finger there for a while then will turn to Red
Red - The Wii Console is off
Blue - You are connected to Wiiconnect24. When it turns Blue, It means you are getting a message from the Wii Console or on Standby Mode
Feb 06, 2010 | Nintendo Wii Console
My wii console will not turn on. It acts like no power is getting to it.
Check your wii adaptor, In normal conditions the wii adaptor provides the output 12volt. and indicator red light is ON. You can test the output using multimeter or a 12volt lamp.
hopefully this help..
Jan 16, 2010 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
Our WII won't turn on no power? Any Ideas?
the power went out and now my wii won't turn on and hte power source is good?
Nov 07, 2009 | Nintendo Wii Console
The wii menu does not appear on the tv screen but have green light on the wii console and i cannot close that wii...someone can help me..
First check your cable connection.
Eject the disk, if you have inside.
Unplug the console at the back
Wait 10 minutes
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
If this not help may your Wii need service.
Oct 29, 2009 | Nintendo Wii Console
Wii remote is not turning on
You probably need to re-sync the Wii Remote.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Source: http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Oct 20, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
27 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
