Had a hard drive meltdown, formatted and reinstalled OS, attempted to reinstall opal system not recognizing player, it recharges and shuts down.
    Genius:
  • 1,416 Answers
HELLO,
What this indicate is that the MP3 player has been corrupted, it will need to be formatted to regain it memory ,you can carefully do this with your computer make use of your USB cord to connect both of them together then access to my computer at the right Conner on the screen click on it the device will open then you will see all the data install in it click on it one after the other or click on all then delete.
or
Make use of the method you in installing on it but it will only delete the data install.
What this means that the reformatting of the MP3 is the best to revive the memory note remove the power connected (battery) to it if any.
Thank you and thanks for using fixya.
Posted on Oct 10, 2010
Hello. My acer aspire 4820tg laptop is unable to start up. When i turn it on, it says that windows is unable to load, and gives me the option to try and repair it. When either doing that or attempting to...
I suggest to reinstall the OS. During the installation process, format the existing system drive/partition/volume and install the OS again. This will fix any software problems or corrupt files. If there are hardware issues, you'l know that when you reboot the machine to log into your account.
Aug 30, 2017 | Computers & Internet
Repairing corrupt harddisk
hardisk can be formated as long that bad sector still recognized by windows. but if spendle already defectilve no way to repair. if the problem is in the controler board you can swap that with good one with same specs.
Apr 09, 2010 | Maxtor Hard Drive
Wont do nothing but initializing
Hi.
The procedure below is the full troubleshooting when the RCA Opal is completely irresponsive and not completing initialization.
Try first holding down the Power/Menu button for over ten seconds. This is called soft reset, and will reset the player to default factory settings. This reset will not delete personal files.
Depending on the model you may also have a reset button. In that case hold down the pinhole switch using a paper clip for more than ten seconds to perform an hard reset. It will take one or two minutest to restart the Opal after this reset, as files must be reinstalled.This reset will delete files and personal settings.
If that does not work, it means that system files are damaged. In that case you will need to reinstall the Opal firmware. Firmware for some model may be available online, but better calling or contacting RCA and asking them to provide you with an updated firmware for your unit. If the wrong firmware is installed the Opal may result damaged.
RCA can be contacted at the number listed on Opal documentation. Number in US should be: 1-800-878-5779 (RCA Audio Products Repair Centers and Warranty Info).
You can also get the firmware asking a question online. Use the following link: Create an Incident or ask a question.
See also: Information on RCA Opal M4001 MP3 Player.
To update firmware follow procedure below:
Download the firmware upgrade file.
Hold down the play/pause button for about twenty seconds .
Hold down menu button for more than 10 seconds
Keep holding play/pause button and attach Opal USB cable to computer at the same time.
The firmware upgrade will start
If you get an error saying that Windows cannot write to the Opal drive, that means that the Opal internal drive must be re-formatted. In that case go to Computer, click the right button of mouse on the Opal, and choose Format from the dropdown menu.
After formatting, restart both units, and restart firmware upgrade procedure.
Regards.
Mar 31, 2010 | RCA OPAL M4001 MP3 Player
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Hard drive not recognized
format your hard drive completly with this http://www.killdisk.com/downloadfree.htm
you have to create a boot cd with this software.
once formated reinstall your OS.
But if bios does not see this HD it it's also mean that is dead.
Jan 01, 2009 | Toshiba Satellite 1400-S151 Notebook
RESET didn't work
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device.
Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Dec 02, 2008 | RCA OPAL M4001 MP3 Player
Rca m4204-a
Fatal error on RCA Opal:
What do I do if I experience a Fatal Error? How Do I reset my Opal?
RCA Opal - Stuck on "Initializing"
Go to this website to reload the firmware:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1415&p_created=1202430585&p_sid=CwOaz8ej&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTIsMTImcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1pbml0aWFsaXppbmc*&p_li=&p_topview=1
Note: websites are subject to change - if you go to http://www.rcaaudiovideo.com and go to the page for the RCA Opal m series, you can also find the firmware reload on that page.
-Tha Mp3 Doctor
Aug 30, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4008A
I had this problem.  Backing up data wasn't a concern though, as I hadn't anything on the OPAL yet.
First I let the OPAL charge up for 3 hours.  Then I made sure it was powered off.  I had previously downloaded onto a PC the firmware update for the M4004 which also works on the M4008 and other OPAL's.  I plugged the OPAL into the PC, and booted up the PC. After installing the firmware package in the PC, you get an install screen for the new firmware with a format option for the OPAL.  I selected that option, but the "start" button was greyed out as the PC still couldn;t see the OPAL.  I pressed the reset (paperclip in the back of the OPAL) for about 15 seconds, than held down the "Play" button and waited.  Eventually the software recognized the OPAL, and started to format it.
If you get a dialogue to restart the PC, press NO!  You have to read the instructions that come with the install. Eventually I reformatted the drive, and installed new firmware.
BTW, there was no picture folder after I did this, so I just created a new folder named picture and it worked fine for the thumbnail pics I threw in there.  Also when I use a MAC with the OPAL, I power the MAC up with the OPAL off but attached.  After drag and dropping files into the OPAL, I power down the MAC.  After power down the OPAL will after a pause give the "building databases please wait" messages, then when done go to the start menu.  It is difficult on a MAC to eject the OPAL, it just reappears on the desktop so shutting down is the only safe way to administer the device.  But to update firmware, which is easily corrupted BTW if you unplug the thing at the wrong time,  you HAVE to do it on a PC operating system. Might work on an Intel MAC with a PC OS though.
Hope this helps.
Dec 29, 2007 | RCA OPAL M4001 MP3 Player
RCA opal
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Nov 07, 2007 | RCA OPAL M4001 MP3 Player
12 people viewed this question
 Grubhead
Grubhead
