Question about Sony BDP-S350 Blu-Ray Player
BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE PICTURE ONLY SHOWS IN THE MIDDLE OF THE SCREEN IN A SMALL BOX. NO MATTER WHAT IS TRIED THE PICTURE SIZE WILL NOT INCREASE. THE PLAYER KEEPS READING LOADING. I'VE TRIED ADJUSTING THE SCREEN RESOLUTION, UPDATING THE PLAYER & THERE WERE NO SOFTWARE UPDATES. ANY CLUE HOW TO FIX?
This problem is easily fixed! I also have a BDP-S350, and had the same issue on "Crank 2-High Voltage". The fix is to put a USB memory stick into the port at the back of the player, 1GB is plenty big enough. This film and others play fine on PS3's or anything that has internal memory, but the 350 needs a memory stick permanently fitted. Also, make sure you have the latest firmware update on your player. Happy viewing!
Posted on Oct 11, 2010
  • carl87gt Jun 13, 2011
    Had the exact same problem on my Sony BDP-BX1. Checked several cables and several discs. I could only get it to occur on Crank 2. I put a 1 GB thumb drive in the unit and it worked fine (had to power down & back on). Thanks David.
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
24 inch screen shows about about 15 inches square
Check your cables connections and try other input plugs. If you are trying to watch a DVD, check your dvd (or other equipment resolution/size options. Nothing in the user guide gives you setting options. Although you should hit the PICTURE button and try different options.
Feb 27, 2013 | Insignia NS-24 TV TV
My tv's picture does not cover the entire size of the tv. The picture that shows is the size of a square and my television is a rectangular size. How do I widen the picture?
there should be a button on your remote that adjusts the picture to fit your screen. They have that on most tv's. Are you using a cable box? your cable box also has settings depending on what your using. 1080i, 720p? does it do the same thing with a dvd player or game console hooked up?
Mar 02, 2011 | Sylvania LC370SL8 37 in. LCD Television
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
Dec 29, 2009 | Sony BDP-S350 Blu-Ray Player
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Jul 10, 2009 | JVC AV-36150 36" TV
Picture won't change sizes
If you are using a cable box, the settings you want are in the setting menu under "format" or "display" . Typically the choices are Normal or stretch, Select stretch.
The "small picture is how the old NTSC format displays in "normal mode" on a High definition set.
While you are in the settings menu, you might want to verify that the box is set to output at least 720P if not 1080i.
www.mcveyelectronics.com
Apr 07, 2009 | Toshiba 42HL167 42 in. LCD Television
Smalll Picture
In the projector's menu under "aspect ratio" is sounds as though you have it set to "native"
this setting usually results in a small image.
Try either the 16x9 or the 4x3 setting depending on the aspect ratio of the source. I hope this helps you.
Cheers
Dec 28, 2008 | InFocus ScreenPlay 7205 Multimedia...
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
Hi text size small and web pages in middle of screen , tried changing text size but doesn't work . tried system restore and says it didn't work properly. many thanks for any help
Top of web-page Click View ( then text size to suit )
Page in the middle of screen, click Full-Screen Icon ( Top right of page ) Square Box.
Or highlight corner of Page and Drag To required Size.
Mike @ compurepair.
Mar 07, 2008 | Computers & Internet
Sony BDP-S350 Blu-Ray Player Logo
523 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
