Phone line fault
After thunder storm Tuesday night . When PC is on line all other land lines in house signal engaged from exterior & no dialling tone. I have changed all filters with new. Still no joy
  • 1 more comment
  • HTB7 Jun 02, 2008
    Nothing has solved the problem so far. I am contacting BT. Will let you know the outcome. Regards HTB7
  • Chuck Munger May 11, 2010
    assuming that you have the good old dialup style modem in your PC also attached so that you can use it as a fax modem the modem may have gotten popped. Also one of the filters may have taken a hit too.
  • K L'Heureux May 11, 2010
    Have you tried looking at the modem boxes themselves, might be that one got over juiced.
  • 55 Answers
Your modem card got bad. Replace your modem card. this is a common problem.
Good luck.
Posted on May 30, 2008
My panasonic landline dect 6.0 goes straight to answerphone instead of ringing. You advice would be appreciated. Thanks. Joy
when you pick up a handset can you hear a dialling tone? If you can that mean the line is ok - so the problem could be the phone settings or at worst phone fault - suggest you reset the phone as it might be programmed to go straight to ansaphone
Jan 10, 2018 | Panasonic Lands Phones
Caller gets engaged signal. I get no dial tone, dial number is dead / does not ring.
take the phone to a friends/neighbours and plug in to test for a dial tone
if no tone , have the phone fixed
if there is a dial tone call the service provider and ask for a repair to your line
Oct 18, 2017 | Lands Phones
Why does screen read 'Searching' also have no dialling tone
Dear Pam,
The symptom you are having occurs only on a cell phone, and it happens when you phone is out of range of a tower.
Cell phones use signals that are relayed from towers, which is why many phones do not work at all way out in the country.
They are too far from a tower.
Most cell phones have some sort of an icon on the screen showing a thing resembling a tower, with some lines or bars along side it, showing you the strength of your signal.
The more lines or bars, the stronger your signal.
When you get too far from a tower, you will have no bars, and no reception.
God bless your efforts.
Dec 20, 2016 | Lands Phones
No line displayed on handset. No dialling tone. Unable to make or receive calls.
At the cost of asking the obvious, please check phone line connection to the wall and the phone. Sometimes a minor disconnect can lose you dialing tone. If the phone company says line is good, try other phone jacks to see if you get dial tone.
Oct 21, 2014 | Lands Phones
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
Cant make call out as it appears that there is a line open
2 more things to try:
Try plugging in the base station into a different phone jack somewhere in the house: if it works, the first jack is dead and will need to be replaced, otherwise try the folowing:
Try using your base station at a neighbors house, (somewhere where you know the phone line is working), if it works there then its an issue with your telephone line, however if the base station does not work there, then I would look into what is going on with the phone.
if you determine that it is your phone line, I would contact your telephone company and talk to them about sending a technician out to fix it.
Let me know how things turn out!
Thanks,
Mike
May 17, 2010 | Uniden Cordless Phone
Dead machine
yes there is a hope depending on the damage.likely it was the power supply fault.
May 16, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Geowilmil
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
Computers & Internet Logo
David Payne
David Payne
