Question about Garmin GPS 12XL GPS Receiver
When i open garmin 12xl it gev me vois when i press page bottom this message show me (Memory Battery is Low ) how to solve this
  • 1,606 Answers
The memory battery is a BTR2032 or a CR2032. This is one of those coin type batteries. To replace it you need to open the case and depending on when your unit was made you will either find a battery hold or the battery will have wires soldered to it.
The batteries are cheap. Usually under $1. Getting someone to change might cost a bit. If this battery goes out then your unit will forget settings and so on and have to reload everything from scratch every time you use it. It will work fine but might take 5-10 minutes (depends on how many sattilites it can see) to get running.
Posted on Oct 10, 2010
My Garmin GPS 12 XL will not power up. Is that an internal battery problem or is the unit shot as Garmin technicians tell me?
try swapping out the batteries, no harm in opening it up with a screw driver (will void the "warranty" that expired 12 years ago) check if there is an internal battery (usually a coin cell battery like cr 2025 or CR2020) otherwise it is dead and time to get an e-trex 30... great simple little unit with lots more features
Jul 09, 2014 | Garmin GPS 12XL GPS Receiver
I have no Maps when I turn on the Garmin, there is a blue arrow and thats all, no back ground at all
The map may be unselected. To select it;
  • Press TOOLS (The spanner icon on the right bottom of the page that shows WHERE TO and VIEW MAP)
  • Press SETTINGS or LOCALE on models that don't have a SETTINGS icon
  • Press MAPS
  • At the bottom of the screen press MAP INFO
This takes you to a screen that shows whatever maps are on the satnav. If there's not a tick beside the map name the map is unselected. Press on the map name and it will become selected. This should solve your problem.
Feb 02, 2011 | Garmin nuvi 1300 Car GPS Receiver
I am getting a Memory Battery is Low - how do I recharge or replace teh memory batter. I only load AAA batteries into the equipment?
The memory battery is normally charged by the AA batteries. Leave the batteries in for 5 days. If this doesn't recharge the memory battery then it needs replacing. It's recommended that you send the unit back to Garmin to have it replaced. The memory battery is a Panasonic VL 1220. If you want to attempt changing the battery yourself there's some information on how to do so at http://forums.groundspeak.com/GC/lofiversion/index.php?t38975.html
Nov 08, 2010 | Garmin GPS 12XL GPS Receiver
My garmin 12 xl will not turn on under battery power. it works with the power cord
check it out manual regarding battery hours and if it is damaged try to replace under warranty options with out error
Dec 14, 2009 | Garmin GPS 12XL GPS Receiver
Replacement of the memory battery of my Garmin 195
Piece of cake. Remove screws from back of device. Separate the housing and carefully lift up circuit card off of pins. There is a battery holder underneath. Simply remove wafer battery and replace with like model battery. Put back together and you're off.
Jun 13, 2009 | Garmin 185 Sounder GPS Receiver
Lost destination after saving it
Sounds like the internal memory battery is run down - it's charged from the AA's. Usually does not recover. Battery (the VL1220) is shown here: http://www.panasonic.com/industrial/battery/oem/chem/lith/vana.htm.
It' easily replaced once the case is open but requires a steady hand with a fine tip soldering iron. Local story started by me here.
Sealing the case up again is very fiddly - hard to make a tidy job with silicone.
Feb 22, 2009 | Garmin GPS 12XL GPS Receiver
Memory Battery Died in my Garmin GPS 12XL...Can I replace it?
Wildstreak, same happened to my GPSMAP 180. Its old and no longer supported by Garmin. I did call them and they gave me the model and number of the battery (mine is a Panasonic) Also advised that units are heat sealed so I am taking mine to a local electdronics shop that also sells Garmin and have them replace the battery.
Seadrive Joe
Aug 29, 2008 | Garmin GPS
Garmin gps 95xl battery
The battery is a Panasonic VL1220. See my local post here about replacement.
Aug 12, 2008 | Garmin GPS 12XL GPS Receiver
What sort of internal memory battery is in my garmin 12xl?
You can find the battery here:
http://www.mouser.com/Search/Refine.aspx?Keyword=658-VL1220-1VC
To open the case, scrape the sealant in the grove around the unit; then use a flat screwdriver, as wide as possible, that fits in the grove. Place the screwdriver on all sides and different places. Rotate the screwdriver gently until the glue tears and both gps housings can be separated.
To replace the battery you will need to be handy in soldering in tight spaces.
Mar 24, 2008 | Garmin GPS 12XL GPS Receiver
Garmin GPS 12XL GPS Receiver Logo
433 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
