Question about Epson RX620 All-In-One InkJet Photo Printer
Removal of border on bottom and right side of 8X10 print of color slide.
When printing 8X10 prints of color slides have a border on the bottom and right side of the print. I was able to print borderless 8X10 until now.
    Novelist:
  • 85 Answers
Hi Sounds like some of your printer settings have changed?
Check print settings and your paper size.
Also check print preview to see if print is different.
If all are OK.
1. Remove both printer cables and switch off printer for at least 1 minute.
2. Remove printer driver from computer control panel/printers
3. Swich off computer
4. Reconnect printer cables
5. Start computer abnd allow it to find printer.
6. Instal driver.
Usually does the trick if all worked OK before!
But if not go to Epson site and download new driver.
Good Luck!
Tinteiros (Ebay)
Posted on May 30, 2008
  • 45 Answers
Well this could be caused by a couple of things that i know about.
1: there is a line of dirton the drum, which may need to be cleaned to clear it.
2: there is a shadow set up when it prints now.
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    Ink is stuck in the printer. I can't get it out.f4280 deskjet
    I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
    http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
    To replace the print cartridges
    1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
    2. Open the print cartridge door.
    The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
    3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
    If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
    1 Print cartridge slot for the tri-color print cartridge
    2 Print cartridge slot for the black print cartridge
    4. Pull the print cartridge towards you out of its slot.
    6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
    1 Copper-colored contacts
    2 Plastic tape with pink pull tab (must be removed before installing)
    3 Ink nozzles under tape
    CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
    these parts can result in clogs, ink failure, and bad electrical connections.
    7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
    If you are installing the tri-color print cartridge, slide it into the left slot.
    If you are installing the black print cartridge, slide it into the right slot.
    Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
    How do i install ink cartridge for HP 4355?
    To install the ink cartridge
    1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
    2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
    3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
    Important : Do not touch copper-colored contacts or retape the cartridges.
    4) Insert the tri-color print cartridge.
    Caution : The device must be On before you can insert the print cartridges.
    a) Slide the tri-color print cartridges into the left slot.
    b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
    5) Insert the black print cartridge.
    a) Slide the black print cartridge into the right slot.
    b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
    c) Make sure both cartridges are secure, Close the print cartridge door.
    6) Align the print cartridges.
    a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
    b) Remove the alignment page from the output tray.
    c) Place the alignment page face down into the document feeder.
    d) Press OK to scan the alignment page.
    After the page has scanned, alignment is complete.
    Hope this helps. Please rate my response.
    Thanks
    Have a good day.
    Dec 01, 2009 | HP Office Equipment & Supplies
    How do I put new cartridge in
    Follow this procedure to install print cartridges in you printer.
    1 Turn on the HP Officejet, and then lift open the print-carriage access door.
    The print carriage moves into view.
    2 After the carriage stops moving, push down on the top of the print
    cartridge to release it, and then pull it toward you out of its slot.
    3 Remove the new print cartridge from its packaging and, being careful to
    touch only the black plastic, gently remove the tape by using the pink pull tab.
    Caution! Do not touch the gold-colored contacts or ink nozzles.
    Once you have removed the plastic tape, install the print cartridge
    immediately to prevent the ink from drying in the nozzles.
    4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
    Press firmly until the print cartridge snaps into place.
    Caution! Do not attempt to push the cartridge straight into the slot.
    It must slide in at a upward slight angle.
    5 Hold the tri-color print cartridge with the HP label on top. Slide the print
    cartridge at a slight angle into the left side of the print carriage.
    It must slide in at a slight upward angle.
    Note: You must install both print cartridges in order for your HP Officejet to work.
    6 Close the print-carriage access door.
    “Press OK to print Align page” appears on the display.
    7 Press OK.
    Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
    HP C4480 Won't Print Borderless
    Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
    Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    I print borderless several times & found white border both side
    This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
    So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
    Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
    HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
    border cannot print bottom side
    but you know you can print if you can do it
    margin up to 1.29 of bottom that simple
    Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
    Inserted new cartridge (#96 black..it will not register that the
    Hi felinemcmeow, you need to remove the cartridges from the printer,
    1. Open the printer cover
    2. Wait until the carriage moves to the right side of the printer and is idle and silent
    3. Press down lightly on top of the cartridge latch
    4. Pull out the bottom of the latch to unlock it
    5. Slide the cartridge out
    6. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer, and then slide the print cartridge into the carriage
    • Install the tri-color cartridge on the left side of the carriage
    • And install the black cartridge on the right side
    Once completed lower the cover and the printer is ready.
    If this does not resolve the problem please come back so we can try another step.
    Nov 12, 2008 | HP Deskjet 6940 InkJet Printer
    Epson RX620 All-In-One InkJet Photo Printer Logo
    106 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
