Question about Car Audio & Video
No radio volume on sony xr-6600rds car radio cassette. Previously responded to cleaning connectors behind removeable front panel but not this time. Cassette volume is fine, problem relates to radio only.
  • 59 Answers
The radio has a bad tuner. Take it to get repaired or replace the radio.
Posted on May 30, 2008
I lost code for my sony xr-m510 car radio
what code? as far as i know, i have never seen a sony radio that is code protected.
Dec 12, 2010 | Sony XR-M510 Cassette Player
How to decode my radio cassette sony model xr-m510.i got remote but no code & show code in.just change my car battery
Sorry...this code will only be available from your Main Dealer or a Radio Decoding Service
May 23, 2010 | Sony XR-M510 Cassette Player
Want to see what connectors are on the back of a sony xr-ca370x radio cassett
Take a look here to see if there is any useful information
http://www.tehnomagazin.com/Auto-radio-car-connector/SONY-Car-Radio-Wiring-Connector.htm
Oct 22, 2009 | Sony Car Audio & Video
Sony XR-C350 - cassettes get rejected
Hi I do not have a solution but my XR-C350 is having the exact same problem. I just had some repair work done on the car and the baterry had to come out. I have not reset the the system so I might try that? Any help would be greatly appreciated
Tony
Oct 10, 2009 | Sony XR-C350 CD Changer
The radio in my sony xr-c2200 sounds fuzy but the cassete sounds fine.
Something may have happened to the Antenna in your car. Check the connections from the back of the radio and where the antenna mounts to your car.
Hope this helps!!
May 30, 2009 | Sony XR-C2200 Cassette Player
Very low sound out of left front speaker, other speakers work fine
Have you tried another speaker? If your left front speaker is in the door as in most cars, it gets banged around a lot. The driver's door gets the most use. This sometimes results in mechanical problems with the speaker, and can cause low sound or distortion. Take the speaker cover off (it may be necessary to remove the door panel in a factory installation), disconnect the speaker and hook another in its place. If the volume is back to normal you know it's the speaker. If not, check the radio and speaker wiring. If the radio itself is at fault because the amplifier is bad, it can be repaired at a service shop. The repair charges might be close to replacement cost these days, so you might consider a new radio if the estimate is high.
Apr 27, 2009 | Sony XR-M510 Cassette Player
Buttons don't work. Sometimes when I click Source button several times, radio gets turned on if I have enough luck, but in most cases it's pointless), then I can change nothing. Volume change, programm...
Try resetting it. Remove front panel, on main unit is an indent that says reset, insert ballpoint to reset and replace front panel. Everything should now work although you will need to reset stations and clock.
Apr 18, 2009 | Sony CDX-L480X CD Player
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
Feb 05, 2009 | Car Audio & Video
Sony xr-ca670 cd player
if this radio has a removable face check connectors behind face,..if so clean these with Qtips/alcohol. and make sure its seated correctly.If it dont then try to locate main radio fuse and remove fuse to reset radio.some radios have a reset on the front panel..
Dec 15, 2007 | Sony XR-CA670X Cassette Player
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
