Question about Dynex 4-Port 10 Mbps Ethernet Hub
I have a laptop with out a wi-fi after i installed the xp the Ethernet receive only 10mbps what should i do.
    President:
  • 2,653 Answers
Visit windows update and install the driver updates.
Let me know if this solves your issue, if not provide me with your laptop model number please.
Posted on Oct 10, 2010
  • 1,606 Answers
It sounds like either the xp driver isn;t the correct one or it is defaulting to a lower speed. You may need to go to the laptop support and download the drivers. XP will try to use its own drivers and sometimes they are not as good as the OEM ones.
As well you will get lower speeds if your antenna is blocked or the laptop is farther away.
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
Wi-fi connection?
Is the WLAN driver installed? Check that it has the latest drivers.
Jan 09, 2014 | Samsung N120-12GBK Netbook
I reinstalled my hardrive in my dell inspirion 1525 laptop, i put in the operating disc, it loaded windows xp but i dont have any sound nor do i hve internet and i have a wireless network already set up in...
you will have to hook up an ethernet cable between your laptop and router to download those files, and you should look and check to make sure all other files and software is installed. If anything else is missing, download them at the same time as well. then disconnect from the ethernet cable, install all drivers and software, reboot, and then see if it is working. Also, make sure the switch is turned on for your wi-fi on the laptop. Almost all dell inspiron laptops have a switch or button to turn the wi-fi- on.
Dec 08, 2010 | Dell Inspiron 1525 Laptop
Lost wi-fi facility
Hi, Well you have formatted the system, so you need to install the Wi-Fi driver in order to access the Wi-Fi. ou must be having the driver CD, If you dot have just download the wi-fi driver from internet and install it on your Laptop and re-start the laptop and you will be able to access the Wi-Fi again.
Regards, polysandy
Apr 26, 2010 | Acer Travelmate 2200 Notebook
Cant connect to wifi
Please tell what is your Wi-Fi LED status. what channel count you configured inside the configuration of router. Please be sure that your wi-fi signal is transmitting or the device is able to receive the wi-fi signal.And please tell what router you using as host and what device you using as receiver. Thanks for subscribing Fixya... All the best
Nov 15, 2009 | Computers & Internet
WIRLESS NOT WORKING
First turn on your wi fi switch on laptop.
Then go to my netowkr places proeprty and make sure your wi fi network adapter driver is installed and enabled.
Then click on view available wi fi networks then check you get signal form wi fi router.Then it works.
Let me know if you need more assistanse.
Aslo you can check in router that wireles is enabled in router?
For that connect your wi fi router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
typoe user as "admin' and password as "admin" or blank or "password"
then check in wireless settings that it is enabled.
Thanks.
Sep 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Drivers for Wi-Fi (drivers for Ethernet Controller and Modem Device on high definition audio bus)
Not much offered at Compaq's driver site for XP. For the modem driver, try the link below, it says it's for Vista, but it should work. If it doesn't then you will need the make and model of the modem, then go to the manufacturer's site or driverguide.com for the drivers, and the same for the wireless, make and model, manufacturer's site or driver guide. To be honest with you, modems are just about obsolete, unless you have dial up at home, you'll probably never use it.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&lang=en&dlc=en&product=3739733
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Atheros AR5007(wi-fi)
Try looking for the driver at driverguide.com
Jul 08, 2008 | Computers & Internet
Dynex 4-Port 10 Mbps Ethernet Hub Logo
77 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
