Question about Jet 3 Ultra Power Chair
I have a jet ultra3 wheel chair...the batteries went completely dead..I put in new batteries but now it wont charge...book says to call a tech if the batteries ever completely discharge..is there a protocal one must follow to get the charger to work after replacing the batteries or is the charger shot?
  • 692 Answers
Its unusual for a charger that was working to stop working because you replaced the batteries. Does your chair operate correctly with the new batteries? If so then I would check the connection of the on-board charger at the controller box located in the front base section ahead of the batteries. Trace the cable from the charger to the controller and make sure it didn't come unplugged from the controller. Your red light on the charger would still light up but you would never charge the batteries. Now if you can locate an off board charger (borrow from a friend or neighbor that has one or borrow one from your local provider) plug it in the charger port located under the front of the joystick and see if the batteries will get fully charged that way. If you can't find any cable problems with the on-board charger and the off-board charger charges the batteries then there is a problem with the on-board charger or the charging system through the controller. It would be cheaper to purchase an off-board charger if the borrowed one works than try to replace the on-board charger. Hope this helps
Posted on Oct 11, 2010
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
Controller has 8 flashing lights
After researching this question for you I came up with a charging issue when the lights keep flashing. This means that battery is either bad or came loose or the charger on board went bad and will not complete the charge my best advice to you is to take it in to a local shop to have it serviced. Thanks for using FixYa! John
Mar 13, 2011 | Pride Mobility Products New Pride Mobility...
The chair has been standing idle for quite some months and the battery is obviously dead. Will I be able to re-charge the batteries or will I need to purchase new ones?thanks
Hi. This depends on how the batteries perform after you recharge them.
Sometimes you can get a bit more life by completely running them flat. Then reverse charge them. Then run flat again and recharge the correct way. Use a light bulb to run them flat. You will need to remove the batteries from the machine to do this. When you charge the batteries, charge them in parallel with a 12 volt car charger. Keep the charge rate down to 4-5 amps.This will ensure that both batteries are charged up to the same level.
Be carefull with batteries, as they give of hydrogen and oxygen gas when charging, and this can explode if there are any sparks from the charger terminals.
After doing this try the batteries in the machine. Charge them with the correct charger and see how far you can travel.
The batteries probably wont be as good as new ones, but they might do for a while.
Good luck. Neil.
Jun 21, 2010 | Jet 3 Ultra Power Chair
My chair wont charge in either of the charging ports
It's either a dead charger or dead battery(ies). You will need a voltage tester meter to check. First check the charger by setting your meter to a setting over 24 volts (your chair is a 24 volt system). Test the voltage at the charging port by placing the two probes into the two outside ports (there's three ports in a triangle...test the two opposite ports.) You should get a reading in excess of 24 volts but less than 26. Now plug the charger into one of the ports and check the voltage again. If the voltage is now higher than the first reading, your charger is working and you will need to replace the batteries, if it is the same, your charger is bad.
Aug 06, 2009 | Pride Mobility Products New Pride Mobility...
New battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Mar 03, 2009 | Jet 3 Ultra Power Chair
Wheel chair will not stayed charged.
Something is discharging your battery. Possible the unit have ground fault that cause the battery lost its charge. Try to remove this ground fault & you will solve the unit problem.
Feb 19, 2009 | Jet 1HD Power Electric Wheelchair
Jet 3 Ultra Power Chair Logo
245 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
