Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony 32 Horizontal pull in on a 32 Sony Trinitron. The picture is in an Hour Glass shape. Is the Horizontal output transisitor gone? Or iis the Flyback transformer/ capacitor in this circuit bad? Thanks, Krist
  • waitkused Jan 31, 2009
    I'm getting the hour glass shaped picture. Please explain solution to a dummy.
  • 2,335 Answers
It more like the tuning capacitor(s) that is connected to the HOT that is defective or a cristalized/dry solder joint nearby the flyback transformer.
Posted on May 30, 2008
Sound but no picture on sonny trinitron
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 13, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron KP-43T90, have sound but no picture it is a 2001.
Check its horizontal output section circuit for fault. Check the horizontal output transistor. If it found leaky, suspect horizontal output transformer.
Dec 21, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Stand By/timer light continous blinking - cannot get picture to come on or how do I turn off the stand by/timer off so the TV picture can come on
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jun 15, 2017 | Sony FD Trinitron WEGA KV-32FS210 32" TV
The picture on my Sony is shaped like an hour glass
There is an apparatus on the back of your picture tube called a yoke.This distributes your picture on your pic tube uniformly.If this or the circuits enabling it malfunction,then you will get distortion-namely an hour glass shape.Tv has to be trouble shooted.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
I have a Sony Trinitron 34" tv. It will not turn on. The red light blinks 6 times then pauses and blinks 6 times again. Is this an easy fix or time to get a new t.v.?
hi,
ur tv has problem with horizontal output stage. check the horizontal output transistor. if it found short replace the same and switch on the tv. if the same fault occur again, then the lot (line output transformer) may be faulty. also check for any dry soldering in the power supply stage and horizontal output sage.
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture shaped like hour glass
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
The picture is convexed,or hour glass.
Sounds like problem in B+ voltage line to horizontal output transistor. Possible bad filter capacitor or leaky diode in power supply.
Dec 22, 2006 | RCA F32672SB 32" TV
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
