Question about iLO (2 GB) MP3 Player
Ilo mp3 2g
How do I reset it. I cant find a manual anywhere.
What you have to do is plug in your mp3 player to your computer. Go to my computer and find the ilo icon or where it says ilo. Right click on the ilo tab and select the format option. A seperate window will appear and at the bottom click start ** THIS WILL ERASE ALL OF YOUR SONGS, BUT IT DOES WORK ** after it is done formatting, it should work just fine
Posted on Jun 03, 2008
Does ilo model #IWT3206 television have reset button ?
It does not appear to have a reset button or any type of reset menu option. http://www.funaiservice.com/manual/ILO/Manual/IWT3206.pdf Some TV's will reset by simply unplugging them from the AC outlet for 1-2 minutes then plugging them back up.
Jan 31, 2012 | iLO IWT3206 TV
I neeed to know how to program my ilo iwt 3206 tv to a one for all urc-3220 remote and cant find a manuall
Try codes for Funai, Orion, Tatung ILO customer service number is 800-289-0980
ILO TV Codes. 11286 11603 11684 11990
ILO TV. 0171 1286 1990 1603 0180 1271 1963 0179 0000 1004 1000 1950 1090 1090
Mar 28, 2011 | iLO IWT3206 TV
Where do i get a universal remote for a ilo tv
U can buy a universal remote anywhere like wal mart,target,ext.The problems with a univeral remotes is,u must enter codes for ur tv model,when u buy it u must enter codes to work.Sometime all the codes in the universal manual u enter will not work.That why spend more money best to buy the original remotes.Try website 1-800-remotes Factory oringinal.Buy an exact as the original remote.
Apr 01, 2010 | iLO 3200 32 in. LCD Television
Need remote codes
You may be able to get help here. This is a link for the owners manual in PDF.
Hope this helps!
http://dukeelectronic.com/Manual/IWT3206.pdf
May 30, 2009 | iLO IWT3206 TV
Ilo remote doesn't work
Frist this tv is made by Funai and they have told me that cant get parts for upto a year,that said it could be the remote sensor in the tv.You will probley have to take it to a shop to have it checked out or if you could get a nother remote from someone who has one like yours thenyou could try that frist. The remote could be ad its self.
Feb 19, 2009 | iLO IWT3206 TV
Frozen Mp3 player
Most of the time, this problem only requires a simple reset. ILo went out of the Mp3 business, so the manual is no longer available to the general public. If your player came with a manual, I would double-check it to see what reset method they reccomend. Also, ILo was notorious for creating websites that were not intuitive - there was no ilo.com or ilo.org, for instance. If your user's manual lists a specific website, if you would kinfdly post it here - many people would benefit.
Most of the time, this freezing issue is caused because the new version of Windows Media Player, version 11, was not compatible with the iLO player. If the manual lists an address for a firmware upgrade I would use that address (and post it also). It is highly likely, however, that the firmware upgrade is not available any longer. A firmware upgrade would resolve the problem permanently.
If there is no firmware upgrade available, and the simple reset does not work, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
May 30, 2008 | iLO (2 GB) MP3 Player
ILO light constant amber - cannot connect to iLO via LAN or serial connection
Hi there ,
If your server is working then go to the the back side of the server and notedown the hardware id of the ilo then in the pc connected to ilo typr ARP -s hardware add then the ip you want to assign then ping the add mentioned by you if it replies the try with this ip add
Feb 27, 2008 | HP Integrity rx4640 Server
Totally Lost now
they say the code is 038
see this page put in remote for search
http://www.funai-corp.com/support/faq.aspx
and if you want to see the manual
http://www.funai-corp.com/support/manuals.aspx
put in 0 for a search, thats a zero to see all.
Jan 03, 2008 | iLO 2600 Television
Ilo 27" flatscreen
I moved and the manual and remote got lost. I bought a ONE FOR ALL remote that has the iLO printed on the add but I can't get the tv to work, I tried all the codes but nothing worked. How can I get a manual from the computer to work this iLO tv, which I am unable to use. Maybe I should have purchased a Sony.
Sep 30, 2007 | iLO Televison & Video
Owners manual
I have created a PDF manual for you I own this model. email me at hddrummer1@charter.net and I will send it to you or anyone else in need of the user manual.
Apr 29, 2007 | iLO 3200 32 in. LCD Television
iLO (2 GB) MP3 Player Logo
115 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
