Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
No output power - Behringer Europower Pmp5000 Powered Mixer Pmp5000
  • Behringer Master
  • 5,603 Answers
It is likely the amps have been blown. Take for repair as further use may cause further damage.
Test the mixer by plugging headphones into the main L and R outputs. Note you will hear only one side of the headphone being these are mono outputs. The level will be low, but will check that the rest of the mixer is working.
ALSO please read my tip on here regarding a hazard of speaker polarity.
Posted on Oct 10, 2010
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 26, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
Very low output no power like used to
This amplifier has a VERY complex output section with a bunch of parallel transistors and several of those may have failed resulting in low output. Two other things can happen: Use of small gauge speaker cables eats up the available power. Changing or using damaged speakers can draastically change perceived sound levels. Checking the output waveform amplitude and voltage under load is with an oscilloscope the only way to diagnose this problem.
Jan 04, 2011 | Peavey Pv 2600 Power Amplifier
Intermittant LR output problems Main outputs (XLR
Intermittent problems cn be a real pain to find... BUT I want you to verify your use of the mixer and its connections as one can cause the output drivers to latch up due to ground bounce.
Make sure your outputs go to the power amps AND into balanced inout at the amps... either XLR or TRS connectors.
Make sure that the amps are POWERED from the same receptacle as the mixer... even if you have to run power back to the mixer. If you power the mixer from a different receptacle at the other end of the room, ground bounce of the safety ground MAY exceed the common mode drive of the mixer and cause the output drivers to latch up or even be destroyed!!!
Aug 11, 2010 | Peavey 32fx USB 32 Channel Mixer
Output and power transformers specs
What??? There is NO output transformer for the Mg50DFX. The outputs are direct driven from hybrid stick TDA type solid state amp chips.
The power transformet is probably about 100 watt size and supplies two voltages... one that feeds a +/- 15 volt three terminal regulators... Probably 22 volts +/- to the regualtors and the other supply will be unregulated to the power amp chips.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
194 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
