Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Drinking dispenser doesn't work..Only trinkles out water? Do you have a fix or idea?
    Sergeant:
    Champion:
  • 351 Answers
Hi it have a water filter if so that may to be changed. if not make sure the water going to refrig has good pressure. hope that helps
Posted on Oct 10, 2010
Can I fix my refrigerator dispenser to only dispense ice and no water
Yes, all you have to do is disconnect the wire that is connected to the solenoid that provides drinking water, not the one for ice.
Sep 08, 2017 | Refrigerators
Can drinking water with lemon prevent kidney stones? Also, I have been told not to drink city water. What is the best water to drink?
Yes, I do believe that it is true. Drinking water is always good and can help to improve our health and hygiene as well. It increases energy and relieves Fatigue, helps to promote weight loss, Flushes out toxins, maintains regularity and moreover is a natural headache remedy as well.Adding a pinch of Lemon to it has proved to remove Kidney stones as well. This can definitely be tried out!.
Aug 27, 2013 | Refrigerators
I just bought last week whirlpool refrigerator from best buy.week past allready and the fridge doesn't make cold water for drink water is warm and taste strange what is wrong with it?since i have...
Before you call for severcie you should run about 1/2 a gallon of water through the system to make sure the it is cleaned out and no air bubbles in the system. But if you do that and it still doesn't correct itself, then YES - call for service.
Aug 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
Drinks depencer not working
check the dispenser lever switch
May 02, 2009 | Refrigerators
Icemaker wont dispense water. worked last night but not today.
without knowing model #, i would check to see if the unit has a resevior for drinking water in the fridge side, could be something as simple as the temp set too low in fridge side and freezing the res. check that out. or it could be that your water valve in the back is faulty. take the hose off in back and have someone push the dispenser lever in the front. if it squirts your valve is good and you probably have somekind of blockage in the plastic tubing somewhere. solid 12 gauge wire works great for that. just run it in the tubing but be careful, you dont want to damage it. good luck.
Mar 20, 2009 | GE Refrigerators
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
The water dispencer dribbles the water out.
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
No agua !
you would have to start with the water supply.
check if you have water coming to the fridge.
close the tap going to the fridge, open the line to the solenoids and open the tap. if there is water then supply is ok.
next check if there is power going to the water solenoid . ( this is different from ice maker solenoid) be sure to know which one.
press the dispenser, there should be power to the solenoid and solenoid should click open. if there is none, electrical problem is present.
last thing to check is the micro switch in the dispenser.
it should have contact when you press the dispenser.
tnx 4 using fixya,
drcool
Oct 29, 2008 | Samsung RS2534 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
