Question about Philips 55P8341 55" Rear Projection Television
Power Problem (Phillips 55P8341 Projection TV)
I've got a Phillips Projection TV with an intermittent power problem. It turns itself off after 5 minutes of being on. Sometimes it won't even power up. The problem continues to elude me. Can anyone shed some light on the subject? my tv powers off after a couple of seconds... the screen never comes on. The power indicator turns from green to red. TV is 18months old
  • 1 more comment
  • beatuifulleg Aug 25, 2008
    My TV cuts off while watching. Once the TV is off the power button flashes on and off.
    Same problem except the power button flashes on and off.
  • rsholtin Nov 22, 2008
    philips 55P8341 Powers up for about 5 mins then will not work.
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
Posted on Sep 04, 2008
Tv turned off by itself now TV button goes on but immediately turns off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 24, 2010 | RCA HD52W59 HDTV Projection Television
I have a philips big screen projection tv modul#55p8341 that turns off after being on for a while. great picture and sound
Your horizontal output chip is going bad after it heats up to a certain point it fails and shuts your set down. After a while if not replaced your set will fail to power up at all.
Aug 13, 2010 | Philips 55P8341 55" Rear Projection...
Mitsubishi WS 65513 turns itself off
Solutions?
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
5 blinks, Sony KP-65WS500 stays up only with one CRT gun at a time....
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
d90a778.jpg Need further help, please let me know.
Bye.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Phillips 52" big screen is looking blurry. Can I tune it myself?
my projection tv color is red I have tried ajusting the color but nothing the pic is still to red
Jul 07, 2008 | Philips 55P8341 55" Rear Projection...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
TV turns itself off after a few seconds, no picture at all
Solutions?
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Phillips model# 60p8341
Let me get this straight, you don't have a picture as long as the unit is on, but when you go to turn off a picture flashes? Questions, first how is the picture when it flashes briefly? Is it normal or with colors misaligned? How is the sound? Could be a loose connection or bad capacitor in the video circuit.
Mar 24, 2008 | Philips 55P8341 55" Rear Projection...
TV dead
You can get the service manual with free tech support at the following link just look uner the phillips / magnavox section.
http://servicemanuals.vstore.ca/
Sep 05, 2006 | Philips 55P8341 55" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
287 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
