Question about Milton Bradley Operation Skill Game
Buzzer on operation not working. nose does light up.
  • tomes
    tomes Jul 14, 2012
    I have the exact same problem. Looking under the board part, I see a metal cylinder with a little metal extension that looks like it should spin (maybe it's the buzzer part?) but it doesn't do so when the circuit is connected (although the nose lights up).
My light on warning buzzer on my focus not working which and were is the fuse for it
My light on warning buzzer ???????? Headlamps on warning chime or buzzer ? What year focus ? Probably not a fuse ! It's part of istrument cluster !
Dec 16, 2016 | Cars & Trucks
How do I disable Headlight On buzzer
the buzzer is there to remind you that the head lights are still on when you exit the car
disabling that buzzer will get you a flat battery by leaving the lights on
a better request would be--- how to fix a problem head light buzzer so that it stops working when the head lights are turned off---
Oct 01, 2016 | 2005 Volkswagen New Beetle Convertible
2 lights. 2 switches and a buzzer. how to connect them to make the buzzer sound when a light is turned on
Copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Above illustration assumes that buzzer is rated for 120Volts.
If doorbell buzzer is rated for 12-24 Vac, then copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer2-300.jpg
You need contactor with 120Volt coil. The light switches turn on light. At that moment, power goes to 12-24V doorbell transformer from hardware store. At same moment, power goes to magnetic coil on contactor. The contactor is a switch, and it connects wires between transformer and the doorbell buzzer. Buzzer turns ON.
When light turns off, buzzer turns off.
http://waterheatertimer.org/H230A.html
Apr 17, 2013 | Electrical Supplies
Hi, the buzzer on our Operation game doesn't work--we bought it used, and the light works nicely, but even with new batteries, it doesn't buzz. Is there a connection issue? (My husband can probably fix it...
I had the same problem. I ended up pulling out and disassembling the battery housing unit, which also contains the red light and a small motor (which vibrates the board and causes the buzzing sound). The motor seemed to have frozen up, apparently from years of disuse and dust accumulation. After rotating the motor with my hand, it loosened up enough to start working again after I put the batteries back in.
May 03, 2011 | Milton Bradley Operation Skill Game
HOW DO I CHANGE THE FUEL FILTER ON MY 2002 GMC YUKON XL I AM HAVING TROUBLE DISCONNECTING THE HOSE END
First - Safety is always the key to working with fuel:
1) Remove from the area of work anything that could ignite the fuel, 'High intensity shop lights, no smoking'
2) Work with a flash light or directional battery operated light if its dark.
Two tools to have in my opinion -
1) Pliers
2) Needle nose
1st - use the pliers to spin/break the hose end loose over the In and out flang of the fuel filter.
2nd - If you have a needle nose pliers which have a very narrow nose end.
Place the nose end all the way at the hose end that's over the fuel filter's intake/output flange.
You then can leverage the hose off by forcing the body of the needle nose up against the body of the filter.
Just like a teeter totter where the body of the filter becomes the /\ fulcrum of the teeter totter.
Hope this makes sense?
Blessings,
A/V Media Guy
Nov 21, 2009 | 2002 GMC Yukon XL
Headlights reminder buzzer malfunctions.
First does the dome light come on when the drivers door is opened? If not check the door switch, if it is not working, the circuit is not completed to turn on the buzzer.
Apr 15, 2009 | 2003 Honda Civic
Lights on buzzer does not work
does your interior light and door light work when the door is open??.the lock mechanism has a micro switch that signifies when the door is open if this dont work niether will the buzzer...its a sound generated by the dash panel insert there is no sepperate buzzer.
Jan 22, 2009 | 2000 Volkswagen Beetle
Park brake
Pull up on your parking brake pedal and make sure it is fully up, If it isn't it should turn off the light and buzzer, if it doesn't there is a switch located on the mechanism it operates that is bad are needs adjusting. I hope this helps you!
Dec 26, 2008 | 1997 Buick LeSabre
Miele w1203 fault
use the small orange tab to tighten down on the light just inside on the top of the door. i had the same symptoms and it fixed them right away.
Oct 03, 2007 | Washing Machines
Milton Bradley Operation Skill Game Logo
396 people viewed this question
Top Milton Bradley Toys Experts
Adam Fjeld
Adam Fjeld
Are you a Milton Bradley Toy Expert? Answer questions, earn points and help others
