I have a 50" RCA Scenium which I purchased in 2003. ($3000) I changed my third lamp yesterday...(the picture was getting dark after 3 years), and was very happy with the picture. Today, after about 2 hrs of operation the picture got really dark in the bottom left third of the screen....really dark. The other 2/3rds of the screen has the bright picture I got right after changing the lamp. I also noticed a few weeks ago when I brought the menu grid up the lettering was skewed. Do I have a bad circuit board or something?
  • 597 Answers
No, you do not have a bad circuit board, the problem is still from the lamp you fixed on it. Have it checked once again to see to it that there was no slight difference in the way you have been fixing it.
If you have a bad circuit board, there would be a complete alteration in the functioning of the television.
Since the problem has to do with the lighting and picture of the television, it has to do with either the lamp or t-com board, so check them both.
Take care
Posted on Oct 10, 2010
How do I change the picture tube
your model doesnt have a picture tube it has a lamp instead which is easially relaced by removing the lamp door screww and then the screws that secure the lamp cartridge then it just s;ides out.
Apr 01, 2012 | RCA Scenium M50WH187 50" HDTV
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
Dark picture!
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Jul 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium HTV won't turn on
My tv is about not even 3 years old, the bulb was already replaced once and now the tv will not turn on, we replaced the bulb again, but no change... The blue lights come on and flash but eventually turn off.
Jul 14, 2008 | RCA Scenium M50WH187 50" HDTV
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture
Assuming that the replacement lamp is good, you could be looking at a bad ballast (lamp power supply) or the switch on the lamp door itself could be causing the issue. The light engine also could cause an issue like that. I would have a technician look at it as this is beyond consumer repair.
Nov 25, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
