Question about Dell Dimension 2400 PC Desktop
On dell dimension 2400 desktop Primary Drive 0 not found. When I hit F12 it does nothing. I can't get to the Diagnostics page.
    President:
  • 2,653 Answers
More than likely your hard drive has crashed. You'll need to replace it and reinstall the operating system.
If you'd like to try and mount the drive to recover files, I'd recommend downloading and burning ubuntu onto a cdr and launching the live version (advice for advance user)
If you'd like a Pro opinion I'd recommend finding a local repair shop that does FREE diagnostics.
Hope this info helps!
Posted on Oct 10, 2010
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
Dell's disk monitoring system has detected that drive 0 on the primary EIDE controller is operating outside of normal specifications
Take this as a S.M.A.R.T. drive warning and start backing up your valuable information. Be prepared for a drive failure.
Mar 15, 2010 | Dell Dimension 2400 PC Desktop
I recently moved and when i went to start up my computer it takes me to a blue screen say memory is being dumped. Prior to that though there is a screen saying that a "0 drive" can not be found. Any idea...
Your 0 Drive is the main hard disk drive in your computer. That is where Windows is installed. If the pc doesn't see it, it cannot start. If you've moved, the hard drive cable or power connection may have come loose. You can try opening the case and reseating all connections and see if that works. If not, it's possible your hard drive is damaged and not working.
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
Cd\dvd writing and reading drive
it sounds like you need to replace to cd drive
Jan 10, 2010 | Dell Dimension 2400 PC Desktop
Diskette drive 0 seeks failure;password
Open the case and reset the BIOS using the jumper: move it from 1-2 pins to 2-3 for 5 minutes.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Won't boot from dvd rom (I'm trying to install Ubuntu Linux)
If your system has one optical drive, press F12 when the Dell screen comes up at boot. then select the drive...
If you have more than one optical drive, the master is the only one that can boot(per Dell).
If the above (F12) does not work, you can try changing the boot order in the BIOS to:
First--CD/DVD
Second--IDE-0 (hard drive)
Third--(any other devices)
Jul 08, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
124 people viewed this question
Alun Cox
