Question about Canon EF 70-200mm f/2.8L IS USM Autofocus Lens
I dropped my 70-200 2.8 canon IS lens. The lens appears finebut autofocus no longer works* What are my best options for repair? My lens is less than a year old bought new. It is also very tough to move the zoom in and out, maybe it is why the camera can no longer autofocus*
  • 21 Answers
Best option for repair is CanonUSA repair service (presuming your are in USA). Your warranty will have their contact info, or you can get if from their web site. Though still under warranty, since it was dropped, I'd guess they would charge for the repair (but might be kind enough to give you a break on costs). Another possibility is a local Canon authorized repair shop, but what, and the extent, of damage may preclude anyone other than Canon's repair location from attempting any repair. Dropping it is a bummer, huh?!
Posted on Oct 16, 2010
Canon Rebel XSi won't autofocus and makes grinding sound
There is nothing that auto-focuses except the circuit in the body - all the motors, gears etc. are in the lenses. If this is a 18-55 lens then more than likely the long shaft gear has broken teeth - a very common problem.
Mar 30, 2013 | Canon Rebel Cameras
I recently purchased this Canon EOS Digital Rebel XS/1000 from Best Buy and happily used it for about 6 weeks, when suddenly the AF button won't work, and when I try to use manual (since I was very...
Does the lens have an aperture ring? Is it set to "A" when you try to autofocus? Have you removed the lens and put it back on? Is it on correctly? Even though Best Buy won't help, if necessary, the camera is still under warranty from Canon.
Jun 29, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon Powershot SD800 IS, has had its lens stuck as if it were zooming out.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon Rebel Xti Wont autofocus
You have your own answer - the lens is damaged, probably beyond economic repair.
Jul 29, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Canon power shot g9 lens
Your best bet would be to have it serviced by a professional to get you going again, those are really excellent cameras. If you'd like to have it repaired, you can have the G9's repaired here: www.camerasandparts.com This place just does the Canons exclusively, they don't work on any other models. The best part, the work through them is superb and they are not expensive at all. It runs $89 for parts / labor on the repair and the servicing for the camera included. Plus they cover shipping back which we like. The best part is the work through them just excellent on the Canons, they'd be the place if you want to have it fixed. Hope that helps you with it, all the best. That's a great little camera.
May 10, 2009 | Canon Cameras
Canon SD 870IS - lens error
May 09, 2009 | Canon PowerShot SD870 IS Digital Camera
Canon ef 50mm 1.4 can't focus <1m
If the AF motor is still alive + spinning, this should be fixable without any replacement parts.
Following URLs might be useful:
http://www.flickr.com/groups/canon_50mm/discuss/72157603775874649/
And this one - detailed instructions how to dismantle this lens and fix the issue similar to yours.
http://www.fotomozaic.ro/artikel.php?idstory=225&s=1
Hope this helps - good luck!
Raf
Jan 30, 2009 | Canon Normal EF 50mm f/1.4 USM Autofocus...
Canon EOS Rebel T2 300X Won't Autofocus or Take Picture. I can manually focus and take a picture, but when autofocus is on, it focuses for a second and then goes out of focus and won't let me snap a...
This may be a problem with the autofocus itself, try the following:
  • If you have a different lens, see if the autofocus works with the other lens. If it does, there may be something wrong with your lens.
  • Clean the contacts (the little metal things between the lens and the camera) with a slightly moist, lint-free cloth
  • Try replacing the battery in the camera
If none of this helps, you may have to take your camera to a qualified repair person to get them to have a look at it.
Feb 25, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
70-300DL Macro Super autofocus problem
It is likely that the lens will need parts. Sigma is not the best for repair parts. Typically, the small nylon gears that control the AF break. It is still a useful piece in manual focus. Repair costs would likely exceed its value.
Feb 17, 2008 | Cameras
Canon sd 600
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 04, 2008 | Canon PowerShot SD600 Digital Camera
Canon EF 70-200mm f/2.8L IS USM Autofocus Lens Logo
271 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
