Question about Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660 it says "the screen is currently locked. press the power key to unlock." I have done this several times and even loaded up the latest software. I still get this message. When i hit the power button, it gives me the screen with Wher tom View map, travel kit. I hit view map and it takes me to a btightness screen Then I hit vack and i get the locked screen message.
  • Garmin Master
  • 589 Answers
The on / off switch on top has 3 positions, it locks all the way right, when the unit is on make sure you have it in the middle.
There are icons near power button that indicate right side lock.
Posted on Oct 20, 2010
I have a Garmin Nuvi 660. Serial # 12P414268. I turn on my GPS and I can't key in my PIN number. Nothing is working. I recently returned from a trip to Kansas. The unit worked great until we were...
Power off your Garmin 660 unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
To back up your Garmin.
  • From the garmin drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  • After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Garmin, but be sure to rename it 'temp.gpx'.
  • On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Garmin where they are actually stored
  • You can also try powering off the unit and hitting the reset button under the antenna, or try the information above but pressing firmly the lower right side of the screen.
    This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    Thanks for using FixYa
    https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
    May 23, 2011 | Garmin Nuvi 660 GPS Receiver
    Nuvi 660 cannot acquire sattelites
    do a proper reset like take the battery out if its optional then press the power button for 30 seconds without connecting the power,if that doent help then you need to reset the software to the factory setting thorugh the menu itself.
    Jul 04, 2008 | GPS
    I have a Garmin Nuvi 650 with an unresponsive screen...can anything be done? Thanks
  • This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    May 20, 2011 | Garmin Nuvi 660 GPS Receiver
    I have garmin nuvi 680 not responde el touch escring
    May 15, 2011 | Garmin Nuvi 660 GPS Receiver
    Nuvi 660 screen locked
    I HAVE THE 205 UNIT MY LOCK IS ON THE POWER BUTTON SLIDE IT TO THE RIGHT IT LOCKS AND PUT IT IN CENTER TO UNLOCK - YOURS SHOULD BE CLOSE TO THAT - HOPE IT HELPS
    May 09, 2010 | Garmin Nuvi 660 GPS Receiver
    Touchscreen not responding.
    There are three levels of fixes, please try them in order:
    1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
    2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
    3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
    Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
    My garmin nuvi 660 na is locked and i cant unlock it
    There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
    Mar 25, 2009 | Garmin Nuvi 660 GPS Receiver
    My garmin nuvi 660 is asking me for a pin and i done have it. i need help
    Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
    So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
    Mar 19, 2009 | Garmin Nuvi 660 GPS Receiver
    Cant enter pin or screen is frozen
    Look near the SN # and press the reset button.
    or
    with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
    Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
    Garmin 660 locked up / frozen
    Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
    May 09, 2008 | Garmin Nuvi 660 GPS Receiver
    Garmin Nuvi 660 GPS Receiver Logo
    116 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
