Question about Nintendo Wii Console
What happened to the games you had paid for and downloaded to you first wii
Did you lose them or did they transfer them over to your new unit?
  • 23 Answers
If you have sent your console to the local Nintendo service and got replaced, they'll transfer everything from the Friend Roaster, Friend codes and Miis to Saves, VC games and WiiWare.
If you simply bought a new one, call the local Nintendo service and see what they could do.
Posted on Jun 01, 2008
I recently bought a new I pad how can I transfer my game from my old I pad I don't want to download the new version and don't want to lose my games or friends
  • If you have your old iPad, back it up with iTunes on your computer.
  • With your new iPad connected to your computer, click the "Restore Backup" in the summary screen of your iPad (on iTunes).
  • You should have your old game data now installed on your new iPad.
  • Update, or buy, a new version of the game on your new iPad
Feb 15, 2015 | Apple iPad Mini
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Transfer of Phonebook address to Nokia X6
You can transfer the contacts to your compauter via data cable through motorola phone tools pc suite then transfer it to ur nokia phone via data cable with help of nokia pc suite.
Jun 15, 2010 | Motorola Mobility RAZR V3
What is error code b9 mean on the brother fax 1030?
Hello :
B9 Light emission intensity error of the LED array .
Check CIS unit (scanner device) or check main PCB .
According the error either one of these units can be faulty or a lose connection but getting to these would require you take apart most of your fax machine . Maybe it's time to purchase a new fax machine .
good luck .
rate please !
Mar 18, 2010 | Brother FAX-1030e Plain Paper Thermal...
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
FRONT AXLE DRIVE NOT ENGAGING 97 SUURBAN
the fork inside the transfer unit maybe broken of lose
Jan 14, 2010 | 1997 Chevrolet Suburban
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Jun 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
Saving Favorites before updating Garmin c340
Use MapSource to transfer the Waypoints from the unit to your PC. If you lose them, you can then transfer them back. (I updated a C330 from 4.40 to 6.10 and did NOT lose them, however.)
Feb 23, 2008 | Garmin StreetPilot c340 GPS Receiver
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
