Question about Toshiba MD13P3 13 in. TV/DVD Combo
I put a disc in and now it will not play or eject. When i turn on the tv i can hear what sounds like the dvd spinning????
    Scholar:
  • 143 Answers
Try unpluging the TV... then plug it in while pressing the eject button! If you have a DVD laser lens cleaning disc at home, use it then try again. It might also be a dirty or scratched disc that's not being read by the laser. Try another disc. Good luck!
Posted on Oct 10, 2010
2 Suggested Answers
SOURCE: 46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Posted on May 25, 2008
Disc
Pull the power plug, let it stop spinning, and then re plug it in. See if that helps eject it.
Sep 03, 2014 | LG RHT497H Digital TV Recorder with 160GB...
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
I have Toshiba Regza 32 with DVD and the disk got struck. It doesnt play or eject. But you can hear the DVD is on, is working. The TV works no problem. How I can ejects the disc from the DVD. Please help!...
Hello
As you feel DVD is woking, that is spinning inside, and there is no picture at all, the fault will be with its defective Laser Pickup Unit. It is a common fault , that this unit bcome damaged. No special rason can be pointed out for that. Just put a cleaning disc into the player, and play it for two or three times. If the fault is due to dust or dirt accumulation to its pick up lens, it will be alright after this procedure. If it does not help, there is no other way than replacing the Laser Picup Unit, with same type and number. OK.
Apr 06, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
We have a brand new LG TV with a built in DVD player. We put in a DVD and the message was "No Signal." DVD will not play. I cannot eject it from the player
Hi:
The only way to diagnose this problem is to take the DVD out and inspect the take up rollers designed to take and eject the disc. If you hear sound when try to eject you may have a bad belt or the take up rollers are oxcided causing slipage during ejecting.
Dec 23, 2010 | LG RU-44SZ61D 44" TV
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
DVD's won't play
I have a somewhat similar problem, but wasn't after a cleaning disk use. Most of the time when I try to use this system now, after I put a DVD in, I start getting a loud buzzing noise (almost as if gears are meshing)
Nov 17, 2008 | LGDVT418 System
Disney C1320PTVD TV/DVD Combi. Won't play discs just makes a spinning sound!?
You have to replace the DVD player. The problem is that parts are not available and it's difficult to open the unit. There are about 20 screws to remove, including four screws hidden behind each fender. You have to pry the fenders and rip them off to break two brackets that hold each fender on. The fenders still hold on fine with the remaining seven tabs on each fender. You have to eject the disc to get the mouth off.
I have a working DVD player for sale. It's from a car TV with a defective picture circuit, but the player runs and I hear the movie soundtrack, so I'm 99% sure it's good. I broke the mouth off the player, but it could be glued back.
If you have a good motherboard for sale with a bad DVD player, I might buy the motherboard from you.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Oct 13, 2008 | Disney DTD1363-CAR 13" TV/DVD
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Toshiba MD13P3 13 in. TV/DVD Combo Logo
151 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
