Question about LG Computers & Internet
My monitor will not come back on after I have gone offline for period of maybe overnight or later in the day. I have to completely shut off the power source and then turn power back on to get it to come on. It also freezes and won't come back on. What do I do. It says it is in power save analog. I don't have any directions to operate that I can locate. I need help please. What can I do to get it back on when I move the mouse? I had more memory installed and since then I have had this problem. Thank You, and I will be waiting for your reply.
sandrew
  • 2961 Answers
SOURCE: Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Posted on Nov 30, 2006
SOURCE: digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Posted on Oct 19, 2007
  • 298 Answers
SOURCE: LG 194wt
Did you check the energy saving settings for the monitor
The display settings in control panel should have a tab
for screen saver that also has settings for the monitor
power saver setting. If there is a setting for Digital Power Saving mode adjust it or disable it.
If this does not solve the problem then you may have to
disable APM in the bios setup
Posted on Nov 13, 2007
  • 383 Answers
SOURCE: HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Posted on Dec 20, 2007
SOURCE: Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
Posted on Apr 28, 2008
Ir i smoke 3 days ago will it show up
I have not heard that smoking raises blood pressure three days later. I have only heard that too much nicotine in the blood during smoking or shortly thereafter might raise it. But, in three days time the nicotine should be gone from the bloodstream. I am not a doctor. Maybe you should ask your doctor. But, keep in mind that most docs hate cigarettes and will blame them for all sorts of things.
Mar 25, 2015 | Health & Beauty
Samsung SyncMaster 2333hd monitor shuts on and off repeatedly or turns off
I had a similar problem with my monitor, it turned out to be a loose connection inside the unit, there is a motherboard inside the monitor, it was between this and the LCD that a cable had come loose, some dismantling of the monitor but worth a try.
Mar 04, 2014 | Samsung SyncMaster Computers & Internet
TV shuts off long periods and then suddenly turns back on.
maybe there are some loose connection only in the power supply
section.
Jan 08, 2010 | Panasonic Televison & Video
Amillo pro 2010 screens gone black tried new inverter still no good cleaned ram no good the xp pro disc is off this laptop but got invalid message when reinstalled the screen went blank two days later cant...
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
Oct 02, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
2007 yukon xl battery dead recharged battery will not start no security light no gages work when you turn the key on. try to start the engine nothing happen like the security system shut down. can you...
We had the same issue with our 2007 Yukon Denali XL. Died on us twice after sitting for short periods of time; once we watched a DVD with the engine off and battery died within 10 minutes. The dealership kept it overnight to troubleshoot why the battery died so quickly. They said the radio was "pulling" too much from the battery. (They supposably fixed it) But again a few days later the battery died again after sitting overnight. We brought it back to the dealership and they brought in a GMC "expert" to replace the entire DVD/CD/Navigation system. They also replaced our battery with a much larger battery, similar to the ones that GMC puts in there diesel trucks. They had our Denali for 5 days, but it appears to be fixed now.
Getting it fixed correctly wasn't without headaches, but it was all covered under warranty, including the battery. And they are updating the nav w/ the new edition disc as well for no charge.
Apr 13, 2009 | 2007 GMC Yukon
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Laptop monitor shutting off after after a few minutes
I have exactly the same problem though I have a toshiba laptop, after 3 years of intensive use i think the lcd is gone, cos it has nothing to do with os as it did the same even when entering setup. btw i used to let it 247 on like you did !
Jan 01, 2009 | Dell Latitude D600 Notebook
Monitor takes 1/2 hour to warm up
You need to check the fly back of your monitor maybe experience over heat. It is possible need for replacement but not the whole monitor only the fly back.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
