Question about ATI RADEON X1650 Graphic Card
Monitor stays black. Says no video.
For about 6 months my x1650 graphics card worked flawlessly. HOwever after those 6 months when i was playing games on my pc the screen would suddenly go black and say "no video". i ran several tests and am 99% positive it is somthing to do with the graphics card itself. then just recently the card wont work at all. when my pc boots there is no display even for a second. do i need to purchase a new card? or is there some kind of fix?
  • 1 more comment
  • EVE_gamer May 30, 2008
    well i know that it is not the monitor or the video cable because i have my old radeon 9550 in right now. however i have not tested it out in safe mode. that is a good idea.
    tried to boot in safe mode but nothing happened whne i did. the screen remained black at startup. also i did findout that my power supply was 300 watts when the required amount was 350. however if i was to get a new power supply do u think that it would work again?
  • EVE_gamer May 31, 2008
    thnx a bunch. i was really not looking forward to buying a completely new card. now there is at least a chance that it will work again with the new power supply.
  • 21 Answers
I'd try running windows in safe mode by holding down f8 at startup. If that ends up working it's probably a setting that is wrong. If all still remains black i'd look at testing another video card and monitor. Either one could be it.
Posted on May 30, 2008
  • 88 Answers
I wouldn't necessarily blame the video card. If the x1650 was a replacement card, do you have the old video card that was pulled out, and if so, can you test it?
Also, if it was a replacement card, did you verify that your PC's power supply was large enough to accomodate the additional power requirements of the x1650?
Finally, if you have a friend with a comparable PC, I would also suggest that you test the card in his/her PC. Try this with and without the same video cable.
  • Lee Eismann May 30, 2008
    Good debugging effort. The old Radeon 9550 proves that the motherboard slot, video card, and monitor are not to blame - that narrows it down to the video card.
    This is what I would do if you intend to keep the system. Since you want to have/install a more powerful video card, you will need more power because the newer video cards require it. Therefore, you should upgrade your power supply to at least 400W. I've done this on older systems for less than $50.
    If you have a Fry's nearby, you can usually find an exact replacement, or try their website at
    Once installed, you can then test your x1650 to see if it will work. I give it better than a 50/50 chance since running at lower voltages usually doesn't cause permanent damage, and your current power supply might be running marginally and getting worse.
    P.S. If you do but a new power supply, make sure you get one that matches the connectors that are supplied with your current one.
My ati radeon x1650 stops working on black ops,but still workin on cod4 mw2
When you say it stops working, does it just go blank after it loads the cinematic? I had an 8600GT with similar specs to your X1650 and it used to go black with Black Ops after the cinematic and stay like that. After I got a new card it worked 100% fine. There is a large possibility that your X1650 is a little out-of-date for perfect Black Ops play.
Dec 14, 2011 | ATI RADEON X1650 Pro, (512 MB) PCI...
Play very low games,I'm 2.0 Gm ram is not sucscesfuly for play games? sorry for may einglsh
If you mean 2 gigabyte are correct. You need to upgrade to at least 3 gigs if not 4 gigs to stay with the times today.
Jan 03, 2011 | ATI RADEON X1650 Graphic Card
Recently, when I play graphics intensive games like devil may cry 4, or resident evil 4, the screen suddenly turns black(and becomes unresponsive(need to manually restart the pc)) or it show the blue...
Looking at your specs, I assume that a Pentium 4 is not enough to run these kinds of games, so the overwhelming amount of data going through the cpu may have been causing your system to overheat.
Do these steps:
(1) Uninstall and then re-install your graphics card driver, if problem persists, go to number 2
(2) Try playing around with the ATI Catalyst settings, set everything there to default
(3) If problem still persists, then I -am- sure that your PC and/or graphics card is way too overheated, in this case:
(a) I recommend getting a heat-monitor (doesn't come cheap though) for your PC, to keep yourself notified of the temperatures of your PC
(b) Try buying more fans and if you can afford it get a water-cooling system
Above all, if you can afford a better -Gaming- PC then I'd suggest that, because your system isn't really that great for new games.
Nov 23, 2010 | ATI RADEON X1650 Graphic Card
ATI Radeon X1650 Pro overheats and videocard shuts down
check if the games take too much memory so that the card not able to work, if you used to play it before without problem, check the card fan if its working,and at the same time check your computer cooling if its cool enough.
Jun 14, 2009 | ATI RADEON X1650 Graphic Card
I bought a 512MB PowerColor ATI Radeon HD3650 DDR2 AGP video card
hey your monitor is not support the resolution , try lower resolution
Jun 13, 2009 | ATI RADEON X1650 Graphic Card
I installed the ATI x1650 but the monitor is blank when I turn on
Yes the card does support the screen. If you have blank screen right from turn on, chack that you have not plugged the monitor into the onboard graphics port instead of your Radeon. If you have plugged it into the right port then you have hardware problems. Could be any of the following:
1. Monitior
2. Video Card
3. System memory
4. Motherboard
5. Powersupply
6. CPU
Try a different monitor and get back to me if you want troubleshooting tips.
May 09, 2009 | ATI RADEON X1650 Graphic Card
VGA Falcox 955, 128T DTV AGP
The game is using all the video ram which is causing the problem. You can try running the game with the bare essentials running in the background but newer games seem to want at least 1 GB of video RAM. Hope this helps.
Feb 14, 2009 | ATI RADEON X1650 Graphic Card
My monitor freezes
since you have laready checked the videocard to be working on your friends pc, the problem may be on your motherboard.
try to do some tweaking on the BIOS and if that will not help, check your directX and softwares installed on your pc. check also if your pc is in its most optimal settings.
Apr 24, 2008 | HIS RADEON X1650 Pro iSilence II Dual,...
I can't play Prey on my new fancy card...
You can try and install the latest patch to the game here:
Also make sure you have the latest drivers for your video card.
Hope this helps!
Mar 24, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 Graphic Card Logo
96 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
