Question about LG WD-3243RHD Front Load Washer / Dryer
No or infrequent spin and LE message
We bought our LG used and have had it for 5 months. We had been out of town for a month and so it was unused. Tried to use it with a medium size load and it won't spin. I can hear the motor trying to spin, the timer counts down, but no spin. Finally, when it gets to the dry cycle, the LE message comes on. Technician came out and was pretty useless. He said it was probably overheating and we should let it cool down between loads. Obviously, when I ran a new load after he left, the same problem occurred with the exception that now it sort of agitates every 10 attempts, but still no proper spin cycle and the LE message again comes on with the dry cycle. Help, please!
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The problem here is the Hall sensor, which is located on the motor. You need to get service and get this replaced and the unit will work once again. Make sure you are using a HE branded detergent.
Sgt 48
Posted on Jun 04, 2008
  • Andrew Lauder Jun 04, 2008
    if you have the ability you can test it yourself.
    Sgt 48
We cleaned our filter and unblocked a pipe at the back of the machine and found that it worked
Posted on May 30, 2008
How do I fix an error code LE on an LG washing machine
We have experienced the LE light for the past several months on our LG Tromm 2277. We replaced the Hall Sensor and it worked for about 4-5 washings. We unplugged and turned the drum 4-5 times in each direction. Replugged and it would work for 4-5 times. When that stopped working, we ordered the Stator Assembly. Same thing. It would wash 4-5 times and the LE light would return. Finally, the washer tripped the breaker and there was no power anywhere. My husband traced power up to the Main Control Board. He noticed the red light on the board was no longer on. The Main Board costs about $150. It arrived (ordered from Sears Parts Dept) and he replaced it in about 10 min. Take a picture of it before you remove so that you will have a guide to re hook. Three days and six washings later, it is still working. If I can get another 3-5 years out of this washer, I'll be happy. I have mastered the musty smell. I use a cleaning tablet "Affresh" designed for cleaning the drum periodically and keep the gasket as dry as possible after final wash using a towel and leave the door open. I love the low water consumption and low detergent use. If you use more than 2 Tablespoons of detergent, you are using too much. I also use a 1/2 teaspoon. of oxy clean when washing whites and towels. Here are two sites for installation reference:
http://www.youtube.com/watch?v=J11Thy0vW0Y
How to Fix an LG Front load washer machine that wont spin Post Comment On Buck Up Chinny
Good Luck! Kathy in Georgia
Sep 09, 2014 | LG WM-2277HW Front Load Washer
Lg wm3677hw the le error code, how do I repair
Some of my notes:
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If it be below that number find the small tube going to the control and blow it out. Get rid of the sediment in the air bell and reconnect tightly. Pump out water and retry.
Hall sensor failure:
When too much of the low-sudsing HE detergent is used in the LG washers (and especially non-HE type detergent)...
The motor & main board will detect suds when the tub begins to spin.
As strange as this sounds--suds causes drag/resistance.
The older hall sensors overheated--the main board would shut-down the washer & flash an error message of "LE".
If the Hall Sensor was not damaged--then the customer would be able to unplug the washer for about 2-3 minutes and plug in the washer again--the washer would be able to be re-started (reboot of the computer).
Eventually--this results in an "LE" error that won't re-set and the Hall Sensor needs to be replaced. The tell-tale symptom of this (aside from a "stuck" LE error) is that when the customer pushes the START button--the tub *wiggles* momentarily before flashing LE again.
On a few occasions--the washer WILL start but the motor GROWLS loudly.
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
LG washer repair manual
Apr 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code LE, will not finish the spin cycle
1) Musty Odor
front door gasket
Apr 01, 2010 | LG WM-2277HW Front Load Washer
Washer display LE error. We have Washer/Dryer LG WM3632HW and sounds like other LG Washers have same problems.
I managed to locate the users manual for your machine here:
http://dl.owneriq.net/e/e181c175-9ece-42cb-9132-c4ab23475aef.pdf
I took the following text from the manual (it also gives you a step by step guide to cleaning the filter):
The water inlet filter
• "lE " error message will blink on the control panel when water does not enter the dispenser.
• If your water is very hard or contains traces of lime deposit, the water inlet filter may become clogged.
We recommend cleaning it every few months.
I hope this helps you out.
Best regards,
Ian
Nov 29, 2009 | LG Washing Machines
LE error code
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
Jun 21, 2009 | LG LDF6810 Built-in Dishwasher
LG LDF6810ST Dishwasher - LE Error
If this LG LFD6810 dishwasher is less than 24 months old, the parts are still covered, just not the labor.
Recommend you contact LG service and discuss your failed wash motor.
And yes, because the impeller (and the motor it is connected to) does not spin freely, it is the culprit.
Good Luck!
Apr 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
LG front washer keeps getting "LE" error. I cleaned out the filter on bottom front left side, but the machine still doesn't spin when it's on. It hand spins when I have the door open, otherwise that's it....
Regarding the LE EEROR CODE.... This code is also caused by having a residue on the sensors in your unit. You have to use a HE liqud detergent.If you use fabric softner use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vineager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE.
The spinning may be a burnt out motor, you may have to get a repairman on that, I can't be sure on that but I hope this helps solve your problem
Mar 23, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-3243RHD Front Load Washer / Dryer Logo
94 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
