Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
I have an Elite french door model 795.777 in which the light for the refrigerator section will operate intermittently when one door or the other is opened. It does not matter which door is opened, and sometimes you can have it open and the light will suddenly blink on even though the door has been open 30 seconds. i looked at the switches on the top, they are at least clean and dry. I hesitate to think that the problem is the bulb since there are two. Any ideas?
  • 410 Answers
On your refrig the control board on the back has relays that turn the interior lights off and on. since you stated the door switches are dry and not sticking i think the relay for the lights has gone bad. you can use sears.com to obtain a part number for the circuit board and replace it yourself. the board is replaced wire for wire and if you can use a screw driver you can replace it yourself..
Posted on Oct 10, 2010
Testimonial: "Thank you, sir. I am leery of these control boards and their short lives. Nonetheless, i made an investment in this machine and will buy a new one. "
  • 1 more comment
  • imconz May 15, 2011
    Hi, I have this exact same refrigerator with the exact same problem. I knew Ihad a bad relay; but, since finding good technical data for an appliance is almost impossible, didn't know where it could be. My refrigerator is in a very tight place so I haven't looked behind it. Am I to understand that the entire board must be replaced or is it possible to replace just the relay?
  • peyton thompson
    peyton thompson May 15, 2011
    replacing the entire board is what i recommend.
  • peyton thompson
    one thing I just thought about you may check with Sears there was a technical recall on some models of these refrigerators that covered the replacement of the control board. also to be safe until the board is replaced remove the light bulbs from the unit to prevent damage to the liners due to heat from the bulbs..
    thx Peyton
ER CF error code on fridge
Sarah can you look in the refrigerator door or around the fresh food section door for a model number that looks like 106.78900 I need that number to be able to tell you what the error code is. Appliance 911 Sea Breeze
Nov 26, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
Fresh food section lights work intermittantly. either door switch can make light flick on and off. could both switches be bad?
I had the same thing happen to my LG LFX25950SB French door style. It is out of warranty but when I called 1-800-243-0000 LG customer service, they were very helpful. The CSR instructed me to take the lightbulbs out and he scheduled a service tech out within 5 days. No charge for parts or labor. I must admit I am impressed.
Jan 28, 2011 | LG LFX25960ST Stainless Steel French Door...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore refregerator lights on/burning even doors are closed
If I understand correctly, you have the bottom freezer with the two doors that open into the fresh food section. Also you have to open one of the two doors first in order to get into the fresh food section. If i ma correct. The switch on the door you have to open first to get into the fresh food section is bad. This is why it makes not difference if you hold both in. The switch on the second door does something else. You will need to replace the switch that the first. You can test this switch by, take the switch out. They are tricky to get out. Take a putty knife and slide it under one end of the switch, push in while you are prying outward. It should pop out. There should be three wires going to the switch. One of the wires is hot (110 Volts), one goes to the fan inside the fridge and the other goes to the light. (The switch operates like this. When you close the door, it turns the light off and the fan on. When you open the door, it turns the fan off and the light on.) Once you find out which one is hot, connect one of the others to it. If the fan comes on try connecting the hot to the other wire. The light in the fridge should turn off. If so replace the switch. I hope you can understand the way I tried to explain.
Please rate solution
Sep 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Mar 15, 2017 | LG LFC21760 Bottom Freezer French Door...
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
432 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
