Question about Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature
Element broke, replaced, now oven heats very slowly and only up to 255
  • Maytag Master
  • 3,740 Answers
This is a symptom of only having 120 VAC power to the oven. When your other element borke it is possible that it tripped only ONE Circuit Breaker. Try resetting the Range CB in the main power panel by physically pushing BOTH breakers to off and then back to on. Then test the range to see if it heats correctly. Let me know the result please.
Also if the problem persists respond with your model number so I can look up a wiring diagram.
Thanks for choosing FixYa,
Kelly
Posted on Oct 10, 2010
Hf3163tn fan and heating element not working. has power to elements and to switches
I'm not familiar with model number;but with fan ovens ,if the fan fails the element it blows onto will over heat and burn out .Its a common fault .
Check for power on fan and element .
If fan doesn't run with power on, or runs slowly or stops occasionally and element with power on does not heat,both will need replacing.
Good luck.
Feb 21, 2018 | Ovens
Elements does not heat up but the oven slowly does... The numbers go back to100 then slowly goes up but does not get hot
how old is this stove
slow stove means an expensive service
first
faulty thermostat
replace the elements
oven door seal
second
the dials
May 29, 2016 | Ovens
Smoke comes out of top when cleaning oven. Oven takes way to much time to cook. Oven does not cook evenly. Items cooked in oven are burnt outside and almost raw inside.
hello jjm... these ovens have two heating elements. when one is bad they still heat but they bake way too slowly. this is the problem here. the fix is to replace the bad element but in my repair service I always replace both heating elements since when one goes the other is usually not far behind.
Apr 28, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
In the upper oven, the lower heating element started sparking when turned on, and now it looks like it has a 'bubbled' area (about inch long) on it and it looks bent on one area. I guess I need to...
Hi, Yes, that element is toast...
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 20, 2010 | GE JKP27 Electric Double Oven
Oven heating element will not heat up
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | Ovens
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Kenwood ck405 - main fan assisted oven not heating up - grill working, fan working but think it might be the element - how easy is it to replace element?
Kenwood Oven not heating? How to replace a Kenwood fan oven element
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Kenwood element How to Repair Home Appliances
Feb 17, 2010 | Ovens
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
Top oven will not turn on elements, bottom oven turns on elements
heatman101
Nov 10, 2009 | Whirlpool GBD307PR Electric Double Oven
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature Logo
157 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
