Acer Aspire One Netbook 8.9" Notebook Logo
Posted on Oct 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i restore factory settings? I'm selling my computer and I want to remove everything. Is that possible?
Anonymous
Level 3:
Master:
  • Master 383 Answers
  • Posted on Oct 10, 2010
Anonymous
Master
Level 3:
Master:
Answers
383
Questions
Helped
80881
Points
1103
Goto the acer website and look for system restore instructions if not you may have to reinstall windows with a usb dvd rom drive or a flash card with windows on it and just format the drive and install all the drivers of the acer site
2answers
I need to restart my computer to a factory settings
1st of all you need to take back up of all your important files and data.
Then Turn off your computer.
Remove everything but the monitor, keyboard and mouse.
Turn on the computer and when see the first screen, press F8 to open the Boot Options Menu.
In the menu you need to find System Recovery Options
Due to every PC different configuration, you need to select Factory Tools and then restore factory setting.
Presses the Yes button and restore system software to factory condition check box and click Next.
After the restore operation is complete, click Finish to restart the computer.
Hope this will work for you ! :)
How do i erase my forgotten password as i want to sell my laptop
There are two things to do. One is assuring you don't have any system restore filesets on the computer from dates after the original ones. Since system restore is different on each PC, that is something you will have to find.
The second thing is erasing all personal files. You can do that if you have a system restore back to factory settings that erases everything, but then for total assurance of non-recovery, you can add a disk defragger that then wipes the free space making everything previously erased non-recoverable blank space.
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Gateway laptop error
Recover at Startup
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
How to restore factory setting on gateway model mt6705
Step 1:
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
GATEWAY WINDOWS 7 FACTORY
Restore factory setting on a sell latitude xpi
If you're concerned about security of your data. Remove the drive from the machine and attach it to an adapter and run a drive wiper software. CCleaner is free. Then reinstall the drive in the machine and use the disks that came with the machine to reinstall the software.
If data isn't sensitive, just use the disks and follow the instructions to reinstall the software. Once that is done find the windows.old file and delete it.
Selling my Toshiba laptop and I want to restore it to default/factory settings. When this was bought did not come with a disc.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya
No disc.how to reset to factory setting
No problem - there are a couple options.
1. Install a new copy of Windows. You can buy this from any computer store, even Target will have this. Once you put the disc in it will walk you through reinstalling Windows which will erase everything and bring it back to a "new" state.
2. Contact Dell to see if they can send/sell you the recovery disc that will restore your computer back to factory settings. You can reach Dell by visiting http://support.dell.com/.
Thanks!
How do i restore factory settings to my packard bell desktop
If you want to restore your computer to factory settings, and you dont mind losing your files, you will need to get the cd recovery disc, put it in the cd-rom drive and reboot your computer. it will start the process from there.
beware, it will erase everything that currently is on there and when finished bring the computer to the original factory settings.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
