Question about Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER -
Where in the feed hose do you put the backup valve for a 380 polaris pool cleaner
  • Zodiac Master
  • 1,631 Answers
Exactly: No more than 3' from the head.
And that first section of hose is the "Soft" Clear style. The Back up Valve will be installed on it... And that hose should be no longer than the deepest part of the pool.
See pic, back up valve inside the square outline...
where in the feed hose do you put the backup valve - in-feed-hose-put-backup-valve-di2jpn2pb5nzkrgf0hzbmyq5-4-0.png
Posted on Mar 16, 2015
  • 990 Answers
About 18" to 3' up the hose from the head.
Posted on Oct 10, 2010
What is a backup valve
Should be located one hose length back from cleaner head. Sort of tear drop shaped in-line with the hose. It has a gear inside that changes water flow so the unit will lift off pool bottom every couple minutes in case it gets stuck in a corner.
Jul 29, 2014 | Polaris 380 In Ground Pool Cleaner
Why on a polaris 380 would water pour out of pressure relief valve and not make it to vacuum
check inline filter or check to see if hose is collapled sometimes the bend where they go into the polaris
Jul 12, 2014 | Polaris 380 In Ground Pool Cleaner
My backup valve on my polaris 380 is not shutting would this cause hose to tangle
no the swivels are stuck move them by hand till they loosen up or replace
Jun 09, 2014 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels won't back up
open up unit check hoses on inside if they are off put on and zip tie
Jul 21, 2012 | Polaris 380 In Ground Pool Cleaner
Have had my current Polaris 380 for around 6 years. Nothing has changed...but suddenly the cast to my backup valve split 3/4ths of the way around above the threads. Replaced with backup valve from...
It is likely a coincidence but you may have a restriction of the water downstream from the device. This would cause a higher pressure and might therefore add to the stress on the backup device. Regardless of the cause you still need to new backup valve or a new part to replace the part that split. They are not hard to replace if you can get it apart.
If you have trouble getting it apart you can bring it down to Leslies Pool Supplies and they can put it back in order for just the price of parts.
I hope this helps.
Sep 04, 2011 | Polaris 380 In Ground Pool Cleaner
I think it is a coincidence. On the other hand, there could be a restriction downstream causing the pressure to be too high. I would check for this but either way you will need to buy a new one. I hope this helps.
My Polaris 380's wheels have stopped moving or move at a very,very slow rate. The pulleys are fine, the inline screen is clean, the booster pump is fine.
remove the backup valve temporarily and note action. If improved - replace valve. Also check head float for water. There should be none present.
Aug 08, 2009 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Having problem with polaris 380 not moving. just replaced back-up valve and having a different problem. there are three small devise on hose that are spraying water.
If the wheels are spinning independently you have broken drive belts. The hose swivels are leaking also which could lower the pressure to the head.
Jul 08, 2009 | Polaris 380 In Ground Pool Cleaner
Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER - Logo
115 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
