Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I added a second door opener button by wiring a door bell switch to the back of the opener, in the same holes that the original door opener button are wired into. Both buttons worked after initial install. seemed too easy. Now after a couple of hours have passed neither door opener button works. The opener in my cars DO work. Any ideas?
    President:
  • 3,197 Answers
I would remove the second door button and see if it returns to normal. There could also be a problem if you installed a 'lighted' door bell button.
Posted on Oct 11, 2010
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
When our neighbour's wireless bell is rung our wireless bell rings as well
Open up the back of your bell and the back of your button. There should be switches you can move. Just move them the same on the button and the bell. This will make it so yours doesn't ring when theirs does.
Sep 11, 2012 | Heath Zenith Designer Series...
Drivers-side rear door won't engage-interior bell chimes constantly
Make sure the rear cargo lid is shut. Then if it still appears to be the door, then remove the jam switch in the door sill. The switches usually separate the wires when the door closes. You do not want to lose the wiring inside the doorjam and you do not want to leave a hole open either.
Tie a string on the wiring and/or tape the wiring to the doorjam until you can get a new switch. Tape the wire ends to prevet shorting.
Feb 04, 2012 | 2008 Chevrolet Uplander
Hi.. my 1/2 horse liftmaster garage door op[ening is having ANM issue the remote in the truck only opens the door doesnt close it anymore...when you click it.....it ticks repeatedly at the 1/2 unit....my...
Ensure that your electric eyes are aligned.
Disconnect the opener from the door and run the door down & up by hand. Does it move smoothly?
Most openers only require momentary contact to get them to open or close.
I have a doorbell button on mine in my house.
Gary
Aug 25, 2011 | liftmaster Chamberlain Garage Door Opener...
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Remote got wet in salt water. Had battery changed
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 5 seconds: Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch. Close driver's door. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Carry out the following button procedure within 40 seconds: Press key lock or unlock button once. Within 3 seconds: Press same key lock or unlock button once. System should now lock and unlock vehicle.
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat button procedure.
If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Open driver's door. NOTE: A maximum of 4 keys can be programmed
This will work providing printed circuit is not damaged in remote
Jul 20, 2010 | 2004 Toyota Camry
The doors do not open by remote control key(BMW 740il 1996 model)
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
To change batteries remove panel back of key then screws on plastic bar
Batteries are available from your local motor factor shop
You might not need new batteries try re programing as described above
Apr 24, 2010 | 1998 BMW 7 Series
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
Central locking went on my lexus took it the garage they said the key wouldn't reprogramme is there anything that can be done
Programming
When
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Close and re-open driver's door. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Insert key into ignition switch. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key from ignition switch. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Within 40 seconds: Simultaneously press and hold key lock and unlock buttons for a maximum of 1,5 seconds. Within 3 seconds: Press any key button for a minimum of 1 second. System should now lock and unlock vehicle once.
Manufacturer: Lexus Model: IS 2,0 200 Engine code: 1G-FE Output: 114 (153) 6200 Tuned for: R-Cat Year: 1999-05
© Autodata Limited 2009 25/02/2010 V8.207M-ukad113581
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat programming procedure.
Within 40 seconds: If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Close driver's door or insert ignition key. NOTE: A maximum of 4 keys can be programmed
Feb 25, 2010 | Lexus IS Cars & Trucks
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
124 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
