Question about Nintendo Wii Console
What is wii Error Code: 51030? - Nintendo Wii Console
SOURCE: cant connect my wii
contacted nintendo support and was given all the help i neede to resolve the problem, everything now works fine thanks.
Posted on Jul 20, 2008
  • 495 Answers
SOURCE: cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
Look for the section for SSID (typically in the "wireless settings" area).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Posted on Oct 20, 2009
fathitkf
  • 1871 Answers
SOURCE: error code for accessing internet 51030
Hello :
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
Check for interference that may be preventing a successful connection..
Check to see if the router you are using is a known to be incompatible. . If your router is known to be incompatible, we recommend using a different router if possible.
Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings
I hope that will help .
rate please !.
Posted on Mar 20, 2010
  • 839 Answers
SOURCE: error Code:51030 Unable to find an accesspoint.
most efficient and best way is to download all the repair guide and keep it in our system, we can use this for our personal future use...
click here to download repair guide
Posted on Dec 15, 2010
clrvuedoc
  • 175 Answers
SOURCE: trying to hook up netflix through the wii console
It is an internet problem. Check out the forum for a solution.
Posted on Mar 13, 2011
My wii is giving me an error message of 51030
Error Code 51030, 51031, 51032 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
Nov 14, 2017 | Video Game Consoles & Games
What does error code 51030 indicate?
Wireless networking issue
Below is a link for error code 51030 troubleshooting
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Dec 27, 2015 | Nintendo Wii Console
Why is 51030 coming up why im trying to get on the internet on my wii.
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51030 is:
"Error Code: 51030Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Apr 29, 2011 | Nintendo Wii Console
51030
"Error Code: 51030
Apr 27, 2011 | Nintendo Wii Console
Error code: 51030
Hi there
you have the error code 51030, you can fix all error codes easily
This needs to be repaired.
you can send the console to Nintendo for free if in warranty, if out of warranty then this will cost you around $150, the whole process will take 4-6 weeks
I prefer the Wii repair guide Method, download the guide and follow the simple step by step instructions and fix the problem in less than an hour, no hassle, low cost everybody is happy.
Best Regards
WiiRestore
Feel free to leave a comment if you need assistance
Mar 11, 2011 | Nintendo Wii Console
Error code 51030 keeps on poping up
Error Code: 51030 (unable to connect to your wireless network)
Check this link -->http://www.nintendo.com/consumer/
Feb 19, 2011 | Nintendo Wii Console
Error Code:51030 Unable to find an accesspoint.
Dec 15, 2010 | Nintendo Wii Console
Trying to hook up to are nintendo so we can get movies from netflix, ran at test got error code 51030 please let me know what to do if anything. thanks
The error code 51030 means that you have and internet connection error. Possibly caused by being too far from the wireless source, or your wireless settings on your Wii need to be adjusted. Here is a link to Nintendo's Customer Support to show you the steps to set up, or reset your wireless connection.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Oct 28, 2010 | Nintendo Wii Console
Cant connect my wii get error 51030
Oct 19, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
123 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
