Question about Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
Beater bar stopped working - Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
  • 1,040 Answers
Here is one of my Tips on the problem you are describing:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
If you have further questions, just let me know.
Good Luck!
Jim
Posted on Oct 10, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
No sprayer and no beater bar movement the vacuum motor is running
you ahve t tilt it back with the button on the back at the bottom thats how you use it and then the beater bar will work and everything it stops when in upright position
Sep 19, 2009 | Hoover F5520 SteamVac Duo Upright Wet...
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue Logo
239 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
