Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Heating but no hot water? i can feel the heat coming off the heater but not getting any hot water?? plz help. i have a raypak rp2100
  • 990 Answers
You have a spring loaded valve inside the water manifold. Open the manifold and make sure that that valve is closing. Then or first make sure if you have a by-pass valve be sure that is almost closed.these will make sure that the water is going through the heater. Also remember you shouldn't be able to feel any hot water at the returns. That is part of what these valves do. They help keep anyone from getting scolded by too hot water. The water at the return should be no more than 7 to 10 degrees hotter than when it goes into the heater.
Posted on Oct 10, 2010
How do you change a senor on raypak r335b
water sensor is mounted to the header of heat exchanger
May 30, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
MY POOL HEATER KEEPS TURNING OFF FOR 2 MINIES AND THEN RUNS FOR 2.WHAT DO I DO
Hold your hand on the inlet manifold. If it is getting hot to the touch then it is a water flow problem and may be in the by-pass inside the manifold. This is a spring loaded valve that let's water pass the heat exchanger and go back out. If it is broken or stuck to much water goes past the heater and the water inside it boils and shuts the heater down. Then while it's off coller water flows in and it resets and goes through the cycle again. I hope this helps. Let me know.
Feb 25, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Would like to increase maximum temp to my spa. Have tried to add resistance to sensor adapter wires coming off thermistor (at input/output headers) to no avail. Using RP2100 raypack - 265K BTU heater with...
Hello Alan. You are going to run into a few internal safety devices that will prevent you from doing what you hope to do. You're going to have a problem overriding the temperature. The Consumer Product Safety Commission and other agencies helped our industry in setting into place "high limits" (therefore the use of high limit switches). It's my understanding according to several doctors that water temperatures over 107 F are dangerous for soaking. You can become so relaxed that your body's core temperature rises! Hyper-thermia is just as dangerous as hypothermia.
Our advice to our customers over the years has been, if the water feels even a little hot (not warm), don't go in. We want our customers to have a safe, long life with their hot tub!
Jan 16, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My raypak rp2100 electronic seems to light the pilot light but then it takes a while to light the gas and when it does it shoots flames out the top of the heater. I'm thinking its the gas valve or the...
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
Aug 13, 2009 | Raypak Rp2100 Digital 336k Btu Propane...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
204 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
