Philips tv Model 24RF50S141. I have lost all the AV input channels. Philips tell me that they have been lost from memory. Can anyone help me restore them?
    Problem Solver:
I have solve the problem myself by going to channel install on the menu and advancing the channels with the right key on the channel line rather than using the channel up/down buttons. Which is partly my stupidity and the Tech at Philips failed to tell me. I was just racking my head and stated trying different things until I discovered the real solution. Besides at my age I have forgotten more things than ever learned!
Thanks for you interest!
Posted on May 31, 2008
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Jan 01, 2011 | Televison & Video
I changed the cabling between my Phillips tv and set-top box a few times and I lost the signal. The signal is from UPC, it's piped tv. They said to locate the av channel on the tv and this would restore...
The only way to change the source for the 28PW8608/05 is to use the remote. On the original remote, just below and to the left of the power button is the button you need. The image on it is a square with an arrow going into the square from one side. The inputs should go TV, EXT1, EXT2, (EXT3 on some models), Front). Depending on the set top box, you may need to enter the setup menu and set the digital source for the input (Press together Fast Rewind and Stop > Setup > Digital Source) or the decorder (next option in Setup).
If you do not have the original remote, you will need universal remote with an input or source button and to find the code that matches the function. Some codes may only operate the basic functions. (The lowest end universal remotes often lack this feature.) A universal remote that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
Dec 29, 2010 | Philips 32PW6506 32" TV
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Philips 21RF vardaan there is no sound but everything works fine
buy a remote for rs 100 . select the AV button on the remote .
May 27, 2009 | Philips 32PW6506 32" TV
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
Universal remote works for basics but won't change input
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
Jan 31, 2009 | Toshiba 32A33 32" TV
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Blank tv screen when turned on
the problem is in your tuner section or video if section check for its proper voltage. if you are not tech. person get the help of tech person it is not a major problem.
Oct 01, 2007 | Philips Magnavox 20MT4405 20" TV
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
