Question about Homelite Mighty Lite Lawn Trimmer
While trimmed is in use, how do I release more trimmer line?
    President:
  • Homelite Master
  • 1,545 Answers
Bumping the string head lightly on the ground will release more trimmer line if the line was loaded properly and spooled in the correct direction. If the line was loaded wrong, doing this procedure won't help. Make sure your line was loaded correctly. Do this bump as the engine is slowing down or running slow. Most all gas trimmers work this way, but some of the electric ones have automatic line feed and no bumping is necessary.
Posted on Oct 10, 2010
Trimmer line runs out FAST
Check the spring tension, if the spring is weak, line can be fed out too quickly.
May 09, 2015 | Husqvarna Garden
Cut line the proper lengh feed thru until both sides are equal start trimming and the line will not feed
You are describing a problem that could be related to the line being too big for your trimmer. It should say what size trimmer line to use in your manual. It may even say on the piece that the line winds around; but you have to look very close
If your line is .080 it may be too big. You should probably use .065
Jim
Aug 06, 2011 | Homelite Mighty Lite Lawn Trimmer
HOW DO i LOAD TRIMMING LINE ONTO THE TRIMMING HEAD OF MY MTD LINE TRIMMER MODEL # MTD LT31C REV POO?
Please see pages 19 thru 23 of your owner's manual. Detailed instructions with diagrams are here.
http://dl.owneriq.net/8/895c4a8d-d94e-49d4-5d45-dc71cf8a717a.pdf
You will need Adobe Reader installed (free, safe, download) installed on your computer to view this.
Nov 07, 2010 | Mtd Garden
Spool does not release line when tapped
You do not need to bump the head to advance the line. The machine has automatic line feed. If the line will not advance, then there is a problem with the line spool, possibly a tangle inside on it. Here is your instruction manual.
http://tinyurl.com/2vz3fhb
Sep 27, 2010 | Black & Decker String Trimmer Cordless 12"...
I have a Ryobi BC 30 trimmer. It runs fine but
Are you using the proper size line? Check the ends of the spool. It will give you the size you need. Also while you are checking, locate the arrow that shows the direction to wind the line. Hope this is of some help...Lee
Oct 05, 2009 | Garden
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Lawn trimmer line
This is a common problem. Make sure you are using the manufacturer's recommended line. When winding the line, try to coil it in nice even rows. This helps me to get a better feed. Good Luck!
Jan 02, 2009 | Ryobi 15" Electric Factory Reconditioned...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Homelite Mighty Lite Lawn Trimmer  Logo
218 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
