Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Boiler stopped working
While we were on vacation our housesitters used our espresso machine and when we returned the machine does not heat up. The green light indicating correct temp never comes on. Naturally no steam. Pump still works but the water is lukewarm. I opened the top and stared at the wires--looks fine and nothing obviously broken or melted.
Any ideas?
Sounds like the thermal fuse has blown on boiler. this is normally caused when boiler is run dry. needs to be serviced professionally
Posted on Aug 07, 2008
My Kitchen Aid Pro Line Espresso Machine has stopped heating the water on the espresso side. It still pumps, but it is not hot. The steamer side works fine.
Hi I have posted a service manual and a parts list here
https://rapidshare.com/files/655646388/kitenaid_service_manual_5KES100.pdf
https://rapidshare.com/files/2923830445/Kitchenaid_5KES100_Repair_Part_List_-_8212198.pdf
It sounds like the boiler element or maybe the thermostat. You have to take the top part of the machine off to get a good look at the water boiler.
I have uploaded a not very good strip guide that I got from the internet, I have used it but it makes thing overly complicated to my mind, but here it is anyway.
https://rapidshare.com/files/3189994876/KES100_strip_guide.zip
It has written instruction that relate to two diagrams in the PDF.
May 19, 2012 | KitchenAid PRO LINE KPES100PM Espresso...
LPG operated usually fine but drops pressure after a couple of hours continous use in our coffee van. Pressure will rise again after 10 mins or so. How do we stop this from happening? Jan
You can do one or two things;
1 - Increase the pressure stat to 1.3 bar,
2 - Raise the water level in the boiler for more thermal mass so that you do not lose as much heat when the machine adds water to the boiler.
Jul 05, 2011 | Rancilio Classe 6 Espresso Machine
Hello all, The boiler of my Trevi Spidem does not heat up anymore. It happened after the machine was descaled with vinegar. Stupid to use vinegar, but it happened. I rinsed the machine very well, but the...
Hi
If the machine turns on and cycles normaly your heating element is probably gone, but if your machine is less than 4 years old you may have a thermostat that can be reset. They are located on the side of the boiler (round boiler and hard to get to) and there is a reset button between the wires going to the thermostats (2). Push the button and listen for a faint click. That may help, but not guarenteed.
Oct 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Not building pressue
Water damage to the flow meter can cause the machine to not function at all. We have seen water leaking from the water tank leaks right on the flow meter and stops the machine from heating and contining its start up proceedure.
Espresso machine Sales and Service.
www.CeriniCoffee.com
johnny@cerinicoffee.com
Sep 04, 2008 | Pasquini Livia 90 Espresso Machine
Steam jet in Saeco Classico
Try Descaling your machine. A lot of times calcium will form on the inside of the boilers and on the heating elements in espresso machines causing heat transfer issue and clogged lines.
If the heating element cannot transfer enough heat fast enough then your steam will run out.
If you need a good descaler or descaling instruction visit www.CeriniCoffee.com
Dec 22, 2007 | Saeco Classico Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
144 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
