Question about Dell DVD-rom DVD Drive
I have a dell 1721, when I try to burn a DVD it reads the DVD fine but when it tells me to instoll blank DVD the drive does not recognize the blank DVD it keeps telling me to put a blank DVD in and the Drive does not open until I restart my computer
  • 384 Answers
Hello and Welcome to Fixya.
Below is a link that will take you to Microsoft's official page where the fix for this problem is available:
DVD Drive Troubleshooting
All you have to do is to click on "Run Now" and follow the on screen prompts - just remember to eject any CD that you may have inside the drive.
Please note that if this does not work, then the drive needs to be replaced. You may contact DELL for replacement options in case that happens.
Hope this helps and Thanks for using FixYa.
Posted on Apr 14, 2011
Dell Inspiron 1420 is not able to read empty cds or DVDS. My I go to properties it shows empty space as 0. When I try to burn a Cd it says " Insert a blank CD"
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
Feb 05, 2014 | Dell DVD-rom DVD Drive
I want to restore my dell inspirion 1721 to factory settings i try the f8 key option but in the advanced boot options there is no "repair your computer" option. what can or should i do?
Your laptop should of come with a disc to restore it back to the factory setting what windows are you running?There should be a restore point you can go back to
Jan 12, 2013 | Dell Inspiron 1721 Notebook
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
Refurbished Dell Optiplex GX280 with DVD/CD-RW Drive will not recognize blank CDs in order to burn music. I was told by the seller that I had to purchase burn software. (I also had to purchase CinePlayer...
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
Jan 16, 2011 | Dell OptiPlex GX280 Desktop PC - Intel...
My gx270 is not recognizing blank dvd disc...how
make sure both the discs and the lens of the cd drive are very clean alot of the time any damage to either will make reading blank discs a chore for any computer
Apr 26, 2010 | Dell OptiPlex GX270 PC Desktop
Dvd drive not recognizing blank disc
Follow the filter fix steps in the Microsoft knowledge base article below.
http://support.microsoft.com/default.aspx/kb/314060
Sep 15, 2009 | Acer Aspire 3680 Laptop
Problems burning a DVD from my Dell Dimesion 3100C
check the jumper on the back of your DVD/CD drive. Try to select it as master then cycle power on your PC and see what happen
Mar 20, 2009 | Dell Dimension 3100 PC Desktop
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
CD burner
Sounds like an issue with the drive. Is your computer still under warranty? If so then I would call dell and get it replaced. If not, then I would replace it myself.
Jan 12, 2007 | Dell (1Y414) DVD+RW Burner
Computers & Internet Logo
Alun Cox
