Question about Sony Playstation 3 (PS3) Console
Hard drive how do i format the hard drive on my ps3
  • heybabemace1 Jul 24, 2008
    console turns on doesn't go to menu screen says,needs to format,then goes to screen saying formatting may lose saved data,then choose yes goes to loading/formatting and stays at 0%?
  • stezzy4u Jul 26, 2008
    >>>> I turned it on and off, I have tried unpluggin all wires for a bit of time then trying to turn it back on, nothing works... hopefully its not worse then it is... because its my brothers PS3 and i messed it up if i cant fix it i will feel terrible.
Was a stock harddrive. i have purchased new hard drive and am awaiting it's arrival, i hope this will fix it?
Posted on Jul 25, 2008
    Problem Solver:
  • 19 Answers
Have you replaced or swapped out the hard drive in your PS3 or is this the "stock" ps3 hard drive
  • Matt Konyn Jul 27, 2008
    It should fix the problem.  You can actually use any 2.5 inch sata drive (laptop hdd) as an internal hdd for you PS3, so you may wanna check out those as they might be cheaper than ordering a new one through sony.  It is fairly easy to set up.  If you have any questions about installation just post here and I can walk you through it.
MY HARD DRIVE WONT LET ME WATCH DOWNLOADED MOVIES ON MY PS3
Could be the video format, make sure the video format is play-able on the PS3 and make sure the hard disk is formatted to a FAT32 file system.
Oct 29, 2012 | Seagate Expansion Portable 1TB USB 3.0...
Cannot complete full format, it take more than 8 hr and at 99 % complete it stops and says "format not complete" , (it works when doing quick format but iam unable to use the drive on my ps3, and...
Welcome to Fixya. If you want to use the drive to your PS3 Console you can still do a Quick Format on the Hard Drive but make sure you select Fat32 File System type to be able for the Ps3 to detect the hard drive. Make sure you use Windows XP or Windows 7 on formatting the hard drive to Fat32 because Windows Vista dont have Fat32 it uses ExFat.
Thanks for using Fixya.
Mar 04, 2011 | SmartDisk FireLite 80 GB Hard Drive
Trying to upgrade my hard drive to 250gb. PS3 will not recognise new hard drive even after I format it to FAT32 on a computer. When I put new hard drive into the PS3 it tells me to format hard drive and if...
If your PS3 is telling you to format your hard drive, then it is recognizing it. You have to reformat the hard drive using the PS3, not your computer. If you don't have the option of formatting your hard drive then you may have to download an update from Sony and then run that disc to format the hard drive. Some of the updates will completely erase all saves, downloads, & etc when done from a disc. So be sure to use this with your new hard drive in the PS3, just to be sure not to lose all your stuff on your old hard drive. Sony has a "walk-thru" on these things on their website.
Jun 08, 2010 | Sony Playstation 3 (PS3) Console
WHEN I TURN MY PLAYSTATION ON IT SAY, "CANNOT START THE CORRECT HARD DISK WAS NOT FOUND"
Try and do a quick format on the hard drive, could of been that somebody switched out the hard drive with one that isn't formatted for the ps3. If it won't let you do a quick format on the hard drive then that means the hard drive that is in the system is bad and would need to be replaced. Once replacing the hard drive then go ahead and quick format it then. It should do it and then you can use the PS3 like you normally would.
May 27, 2010 | Sony Playstation 3 (PS3) Console
Ps3 hard drive will not format PS3 freezes at 99%
mjleadley
If you are using the built in format tool in the PS3 it may not be able to finalize the hard drive properly.
If you have access to a desktop computer the link below will take you through doing a full format of the hard drive with your computer. This way you can see if the hard drive is actually bad. If the hard drive hangs on the full format on the computer then the drive needs to be replaced.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not formating 500gb internal new hard drive?
Hi Eric,
First you will need to connect the hard drive to your computer or a friends, either using a hard drive enclosure or cable
Then you need to format the drive into fat32 format (full format recommended , not quick format)
Then put it back into your ps3 and have a usb flash drive with the latest ps3 software loaded
then you will be able to format the drive and load the ps3 os
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
External hard drive not recognised on my ps3??
Ok. Well this is easy! your hard drive is formatted in NTFS, ps3 wont recognize that. it needs to be fat32 find an XP machine not a vista machine.
download Swiss Army Knife and format the drive in fat32. you will loose ALL information in your external. you will need to back up anything you want to save and put it back after the format.
good luck!
Feb 09, 2009 | Maxtor Hard Drive
Corrupted hard drive
All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
Aug 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
91 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
