Question about Impex Marcy MWM 980 Home Gym
Cable routing - Impex Marcy MWM 980 Home Gym
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
How to in stall a speedomerter cable going to the trans
Check cable routing from transmission side underneath the car up to the firewall and through a hole into passenger compartment. You may have to remove the foot pad and pull back the carpet to see where the cable enters the car the is routed up under the dash to the speedometer. There is a clamp or release that you press on the back of the speedometer while pulling the cable assembly from the back. On the transmission end there is a coupling you unscrew where the cable goes to the trans. Usually on the side and disconnect cable from trans. carefully pull and remove old cable. Pay close attention to how it is routed and any retaining clamps holding the cable in place. Follow new cable instructions . Some have to be greased or graphite added before assembly. Do not bend too far or make sharp turns to the cable. Reassemble and check for noise and needle vibration after test drive.
Aug 02, 2015 | Cars & Trucks
Throttle on 92suzuki katana keeps reving when turn left how to fix
Your throttle cable is mis-adjusted or possibly routed wrong. Has it been replaced? If so, check the routing of the cable assembly. Most all cables have cable housings which mount by some type of clamping device on each end. It sounds as if one end of yours is loose. Best Wishes
Sep 02, 2014 | Motorcycles
Clutch cable routing
Hi Anonymous, it's too bad you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Mar 18, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
Hello, I am rebuilding a '72 Honda CB100 and am having trouble routing the cables under the tank area, around the frame backbone. This would be the trottle cable and clutch cable. Is there an online...
The cable routing guides for new bikes was only to set up the handle bars.
From memory the throttle runs down the RHSof the frame and used to run through a guide mounted off the coil through bolt.
I think the clutch goes around the steering head and also goes down the RHS
Feb 04, 2011 | Honda CB 100 Motorcycles
How to install throttle cable for c77 motorcycle need routing of the cable
Keep the bends gentle. Go from the grip toward the tank down under the tank to the carb.
You may take the tank off and route cable beside frame. If the old cable is there well follow the same route. After you install cable insure that it works freely.
The other cable will lay beside the throttle cable.
I have a 2001 yukon and i need to replace they entire antenna from the antenna base to the radio I can't figure how to route the new cable.
This will require dash removal, the factory routing for the cable is behind and above the airbox. The easiest way to do it if you have not already pulled the old one out is to attach a piece of 16 guage wire to one end of the factory cable before you pull it out, and then when you pull out the old cable it will in turn pull the 16 guage wire through in its place. At this point attach the new cable to the 16 guage wire and pull the 16 guage wire through which will in turn pull your new cable through. If you have already pulled the old cable out and want to install the new through the same route then you will have to remove the airbox, or you can just reroute the new cable.
Nov 22, 2009 | 2002 GMC Yukon XL
Need diagram of routing for the clutch cable
check connection at or right before clutch connection point
Oct 04, 2009 | Volkswagen Cabriolet Cars & Trucks
Amplifier power cable routing.
You have to route it yourself, i suggest not going through the firewall and just going under the car and up through the water drainage holes in the floor of the car.
May 04, 2009 | Sony Xplod 800W Class AB Bridgeable...
Impex Marcy MWM 980 Home Gym Logo
Top Impex Exercise & Fitness Experts
matt
matt
Tom Chichester
Are you an Impex Exercise and Fitnes Expert? Answer questions, earn points and help others
