Question about Frigidaire GLWS1749A Top Load Washer
Top loader model # GLW1749AS4 wont agitate or spin?
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
SOURCE: Kenmore top loader washer noisey agitator
agitator does not work
Posted on Oct 09, 2007
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
Washer goes into spin cycle and will not spin out but it will agitate
Is it a front loader, top loader, what make ? Too many different types and makes to determine the fault. Have you checked to see if the cycle is on drip dry? If it is, the machine wont spin and leaves all the water in the clothes.
Sep 18, 2014 | Washing Machines
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Wont agitate or spin tryied putting on drain spin setting pump will run and run but wont spin
Top loader washers the main reason is either the motor coupling has failed. You will hear a grinding or growling or whirring noise or the lid switch has failed. The lid switchy will keep it from spinning but usually it will agitate. Check and make sure the drum is not froze and won't move, if it is free, check the coupling under the tub and make sure the motor and tranny are connected. If they are then the transmission may have failed. If this is a front loader the main reasons are a bad motor.
Mar 31, 2011 | Washing Machines
Whirlpool top loader model #LA9500XTNO won't agitate
the agitator dogs need replaced sounds like.4 little comma shape pieces underneath the top of agitator
Jan 15, 2010 | Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
May 12, 2009 | Maytag PAV2300 Top Load Washer
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire GLWS1749A Top Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
