Question about Optoma Projector Lamp for EP771, TX771, DX607
Projector stays on for 1min and lamp sutts off
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a BenQ P610 projector.It shows lights for power and after 1min it shows lights for temp and lamp. I replaced the lamp with a brand new one, but there is no difference.please help me to
Check whether the blower is working. If the blower is not working, the temperature goes up and the system will automatically turn off the lamp to protect the lamp. The temperature sensor may also cause this problem.
Jun 12, 2012 | BenQ Office Equipment & Supplies
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Lamp comes on briefly and then goes out
Check poewer connection
Check if fan filder is dirty ( if it is just hoover it out)
If "lamp" light on top of the projector blinks or stays lit - lamp probably faulty
How old is the Projector/lamp (average lamp life is around 2000-3000 hours)
Mar 01, 2011 | Optoma EP719 DLP Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Lamp comes on, but goes off after 30 sec-1min
Sounds like it is overheating. The light must be green when turned on. If the light is red it needs to cool before proceeding.
Oct 07, 2008 | Sanyo PLC XU35 Multimedia Projector
Projector won't stay on
Most projectors have a filter that can be removed and cleaned. Perhaps it is clogged or you may need a new bulb.
Aug 20, 2008 | Office Equipment & Supplies
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Optoma  Projector Lamp for EP771, TX771, DX607 Logo
21 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
