Question about Accele (HRM58MASW) Car Monitor
I have to replace my roof monitor in my car. I need a connector to plug into a round plug. Where can I order one?
  • 1,675 Answers
Hi this is possibly the s-video cable, you can buy them off amazon for a couple of bucks
Posted on Oct 10, 2010
How to remove and replace RIGHT HAND sun visor With lighted mirror on 2004 venture van ?
Remove the screws from the sunshade mounting plate. Pull downwards in order to disengage the sunshade from the roof. Pull down the sunshade in order to access the electrical connectors, if equipped with a vanity mirror. Disconnect the electrical connections from the sunshade, if equipped with a vanity mirror.
Important: Do not rotate the sunshade on shaft. Doing so may cause the sunshade to become mis-aligned and not properly retained.
Remove the sunshade from the roof.
May 25, 2016 | Cars & Trucks
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
Cant find where to plug in power cords for emachines monitor screen E15T3r model 568
AC Adapter For eMachines E15T3r 568 LCD Monitor Charger Power Supply...
As you can see from the picture the power plug is a small round connector similar to an audio input. Power Connectors
look for a connector like the DC socket in the picture
Mar 25, 2014 | MPC Computers MPC F1760I 17" FLAT PANEL...
G6 dome light assembly replacement
This is for the Pontiac G6, 2006 Model year. Remove the Dome Light cover and Lens using a flat screwdriver or fingers, (fingers are best to avoid damage to the plastic). The lighting fixture uses a magnet to attach to the roof. Pull down and detach the fixture, gently as not to damage the roof's fabric. The switch's wiring harness attaches to the fixture by a 4 pin plugged connector. Use a small flat screwdriver to pry the tab up, off of the clip to release the wiring plug from the fixture. Use the reverse order to reinstall after repair. Good luck
Jul 06, 2012 | 2006 Pontiac G6
I HAVE A HP DV2000 LAPTOP WITH VIDEO ISSUES , I REPLACED THE MOTHERBOARD BUT STILL NO PICTURE ALL LIGHTS ARE ON AND THE FAN IS WORKING BUT NO VIDEO..
Hook a spare monitor to the video output, usually on the back. If you get a picture it means the inverter board is bad, or the backlight behind the LCD display, check to make sure the round video cable is plugged into the motherboard. But, if the symptom is the same for both screens, the problem is the Video Graphics Card normally built into the motherboard. If the connector to the LCD is damaged that would explain the issue of no video.
Mar 13, 2012 | HP Pavilion dv2000 Series Laptop Full...
Hello..just moved my desk top to new desk..everything is fine..but mouse won t work..while it was unplugged i cleaned keyboard..monitor with soft cloth..can u tell me why my mouse won t work
IF it's a serial mouse (meaning green round connector) it's probably not plugged in correctly. Now these are not plug and play so you need to reboot your system in order for it to work. Try that.
Jul 10, 2011 | E-Machines eMachines Desktop PC
Order of the connectors on the X7G-NAGAVI?
OK, you will have four connectors (each one with pink and white wires), there are two set of the connectors, two are above the transformer, two below the transformer. The monitor uses four lamps, two for the top side of the screen, two for the bottom side of h screen. You can plug either one of the pair of the connector to the top group of the connector, same for the bottom group of the connectors.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 05, 2010 | Sceptre 17" LCD Monitor
My roof clearance lights are not turning on my 08 Ford Super Duty
The fuse that feeds them is no 22(15amp) in the interior fuse panel,however this fuse feeds the park lamp relay so if your park lamps are working this would not be the problem.
I would suspect that you have a loose or unplugged connector. Most likely connector C913 located behind dash in the top left corner above emergency brake pedal.It will be a round 4 wire cavity connector but will have only 2 wires in it BK/GY and VT/WH.
Mar 16, 2009 | 2008 Ford F 250 Super Duty 4WD
Power (i.e. "switching adapter") needs to be replaced.
Pick up a 100W Universal Laptop PSU which comes with various connectors. There should be one which fits, and there you go :)
Mar 14, 2009 | Computers & Internet
Monitor connector bent pin
It is quite easy to straighten these pins, however the pins are quite brittle, and do not suffer bending too many times (they just snap) Does this cable unscrew at the monitor end? if you have straightened the pin on the cable but are worried that it may be a little weak on that end, swap the ends of the cable round and use the other end to plug into your computer (as it will be stronger) Also if the cable unplugs at the monitor end it can be replaced with a cable of the same type, available from most computer stockists, just take the broken cable with you for comparison Gareth
Jul 26, 2007 | MPC Computers Envision EN 5100e 15" Flat...
Car Audio & Video Logo
Top Accele Car Audio & Video Experts
xxxxxx xxx
Are you an Accele Car Audio and Video Expert? Answer questions, earn points and help others
