HP PSC 2355 All in One When printing Avery address labels, the clear sickum attached itself to the inside of the printer. The sheet was printed correctly on the proper side directly on the paper after the adhesive side had been rolled off, some around the rubber rollers but mostly before reaching the area under the top lid. Printer will not print - says there is a paper jam.
I tried to remove the tape from one of the rollers which was the only evidence of tape remaining but could not. There was no evidence of a paper jam but still the air message appeared that there was one.
I have recently paid $109 for advice about the printer which still was not working properly. I went to Costco and bought a Cannon printer. I intend to get one at a later date that prints on both sides but it wont be an HP.
Posted on Jun 03, 2008
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
I am trying to print using Avery 8663 clear mailing labels using my HP Photosmart 3310 all in one. The printer keeps shooting out the paper with the message "please remove the paper and re-insert it with...
Does it still print on plain paper? Check to see if you are missing one or more labels as they may have come off and onto a roller or other part. I've found that label sheets with any labels removed prior to printing are always prone to loosing labels in the process of traveling through the printer.
Dec 07, 2008 | HP Photosmart 3310 Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
Avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Oct 08, 2007 | Avery DesignPro 2000 for PC
HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sep 21, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Jun 24, 2007 | HP PSC 2355 All-In-One InkJet Printer
148 people viewed this question
k24674
jasbo
jasbo
